Basic Flash Programming and the process in integrating Cortex M0
Hello Guys!
I am Integrating Cortex-M0 with peripherals and memories. Previously I used Block ROM/RAM in FPGA where I just uploaded COE files to make it run. But now I want to use an external flash to do the Job. I have the following questions which I was actively searching but could not solve.
1. Are there any commercial external Flash where I can attach with the processor?
2. I have seen that Keil has an adapter named ULINK 2 to program the flash. But how can I write the flash with or without the processor? Because I only have the FPGA to synthesize the processor and peripherals. Do I need to make a PCB for programming the flash or where can I get the hardware?
3. If I use the flash how can I write the flash, I mean any guidance regarding the programming?
Thank you for your help in advance. Please note that I am a beginner in this process.
Kind regards
Md Mezanur Rahman
