Hello people.
I am using the project "">github.com/.../DAPLink", to program the flash memory of the LPC1857 microcontroller.
- As I understand it, to add a new microcontroller to the project it is necessary to generate a BLOB according to the file "DAPLink / docs / PORT_TARGET_FAMILY.md". This file references the project "">github.com/.../FlashAlgo" to generate the BLOB.Within this repository "FlashAlgo" has two python projects, "flash_algo.py and generate_blobs.py".
I have some doubts:- How should I use this software, flash_algo and generate_blobs?- In the generete_blobs software, I need to pass two arguments: elf_pach and blob_start. What should be the content of these arguments?- In the flash_algo software, I need to pass two arguments, input and template. What should be the content of these arguments?
Thank you in advance for the support.
