Hi everyone!
I'm trying to measure a PWM frequency signal using the input capture channel 1 of TIM3, but it won't work.
i'm using NUCLEO F446RE board, here is my code:
#include "stm32f4xx.h" // Device header#include "lcd_H.h"
int main(void){ uint16_t capt1 = 0, capt2 = 0; uint8_t lock = 1; float Freq = 0.00; //Clock Setup RCC ->CR |= 1 << 18; //Enable bypass HSE RCC ->CR |= 1 << 16; //Enable HSE while(!(RCC ->CR & (1 << 17))); //wait HSE is ready RCC ->CFGR &= ~(1 << 1); //HSE is used as system clock RCC ->CFGR |= 1 << 0;
/**************************************************************************************/ //Configure PA6 as Input Capture channel 1 RCC ->AHB1ENR |= 1 << 0; //Enable clock for GPIOA GPIOA ->MODER &= ~(1 << 12); //PA6 is used as Alternate function Mode: 10 GPIOA ->MODER |= (1 << 13); GPIOA ->PUPDR &= ~(1 << 12); //Pull Down in PA6 : 10 GPIOA ->PUPDR |= (1 << 13); GPIOA ->AFR[0] |= 1 << 24; //PA6 is Alternate function 1: 0001 /**************************************************************************************/ //Configure TIM3 LcdInit(); RCC ->APB1ENR |= 1 << 1; //Enable clock for TIM3 TIM3 ->ARR = 0xFFFF; TIM3 ->PSC = 0; TIM3 ->CR1 |= 1 << 0; //Enable counter TIM3 ->CCMR1 = 0x01; //01: CC1 channel is configured as input, IC1 is mapped on TI1 //IC1F: 0000 No filter, sampling is done at fDTS //IC1PSC: Input capture 1 prescaler: 00 no prescaler, capture is done each time an edge is detected on the capture input TIM3 ->CCER |= (1 << 0); //1: Capture enabled /**************************************************************************************/ while(1) { TIM3 ->SR &= ~(1 << 1); //CLEAR Flag while(!(TIM3 ->SR & (1 << 1))); //Wait a capture occurs if(lock){ capt1 = TIM3 ->CCR1; lock = 0; } else{ capt2 = TIM3 ->CCR1; if(capt2 > capt1) { Freq = capt2 - capt1; } else{ Freq = ((0xffff-capt1)+capt2) +1; } Freq = (float)8000000.00/Freq; //Print value in the LCD LcdSendData(0x01, COMMAND_MODE); //Clear LCD LcdSetCursor(1, 1); LcdSendString("F="); LcdPrintfloat(Freq); LcdSendString("Hz"); lock = 1; }
In debugging the code stuck here while(!(TIM3 ->SR & (1 << 1))); please any help?
Thank you.
This is ST stuff - nothing to do with Keil or ARM:
https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
