I am trying to play a wav file from an SD card. I use Landtiger Board, the communication between the microcontroller LPC1768 and the SD card runs through the SPI interface. I managed to open a file with the help of Fat32 library and read the contents of the file, but now I want to play it. could you please help me which steps should i take now or is there maybe an example.thank you
This has been done countless times - have you googled ?
what i found didnt help me
so what did you find?
you should at least have identified what you need to do - even if you're not sure how to do that.
the secret of software design is to keep breaking down the bigger tasks - that you don't understand - into smaller, more manageable ones...
where are you stuck?
I do not know if I should convert the contents of the file with the help of DA converter or maybe there are libraries from Sound Player.
I think just using DA converter is not enough
If that's what you wanted to know, why did you not ask that?
so what do the examples that you found do?
you should find at least two approaches ...
Raul77 said:I think just using DA converter is not enough
why do you think that?
what else do you think might be required?
Raul77 said:I don't have much idea about the topic
So google it!
