Cortex-M0--Simple APB peripheral Design (LED)
Hello Guys,
I connected the peripheral (LED) with cortex-M0 processor and APB BUS using CMSDK in FPGA of the spartan 6 family. I used the AHB-APB bridge to connect it to the processor. I am attaching the peripheral in the code section. I wrote startup code in assembly. The address of LED is 0x40000000. I was trying to send multiple values in peripheral using a loop.
I see the expected values in the LED in behavioral simulation in Xilinx ISE. But When I run post route simulation only the first value is sent to the LED and other values do not appear in LED. When I implemented in the FPGA I don't see multiple values assigned to the LED. Only the first value is assigned just like post route simulation. I am stuck here for almost a month but could not get to solve it. Is there any design guideline that I am missing in the peripheral that I need to follow?
-------------------------this is verilog file of APB-LED-----
module APB2LED(
	//AHBLITE INTERFACE
	    //Global Signal
			input wire PCLK,
			input wire PRESETn,
		//Slave Select Signals
			input wire PSEL,
		//Address, Control & Write Data
			input wire PREADY,
			input wire [11:0] PADDR,
			input wire PWRITE,
			input wire PENABLE,
			input wire [31:0] PWDATA,
			input wire PSLVERR,
		// Transfer Response & Read Data
			output wire [31:0] PRDATA,
		//LED Output
			output wire [7:0] PLED
//signals
  wire read_enable_LED;
  wire write_enable_LED;
  wire write_enable_LED_01;
//Address Phase Sampling Registers
  reg [7:0] pLED;
  assign  read_enable_LED  = PSEL & (~PWRITE); // assert for whole APB read transfer
  assign  write_enable_LED = PSEL & (~PENABLE) & PWRITE; // assert for 1st cycle of write transfer
  assign  write_enable_LED_01 = write_enable_LED & (PADDR[11:2] == 10'h000);
//Data Phase data transfer
  always @(posedge PCLK or negedge PRESETn)
  begin
    if(!PRESETn)
      pLED <= 8'b0000_0000;
    else if(write_enable_LED_01)
      pLED <= PWDATA[7:0];
  end
//Transfer Response
  assign PREADY = 1'b1; //PREADY = 1
  assign PSLVERR = 1'b0; //PREADY = 0
//Read Data
  assign PRDATA = (read_enable_LED) ? {24'b0,pLED} : {32{1'b0}};
  assign PLED = pLED;
endmodule
