I am working on M4 microcontroller. I would like to perform soft reset of the system. so I have used NVIC_SystemReset function as shown below
__STATIC_INLINE void __NVIC_SystemReset(void) { __DSB(); /* Ensure all outstanding memory accesses included buffered write are completed before reset */ SCB->AIRCR = (uint32_t)((0x5FAUL << SCB_AIRCR_VECTKEY_Pos) | (SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) | SCB_AIRCR_SYSRESETREQ_Msk ); /* Keep priority group unchanged */ __DSB(); /* Ensure completion of memory access */ for(;;) /* wait until reset */ { __NOP(); } }
When I do this, the system gets restarts only when I do power-on reset or Reset in keil debug window. Is this correct operation?
I need the processor gets restart without doing power-on reset or Resetting from keil debug window. please let me know if anyone has solution
thanks in advance
Thanks for suggestions
1) I tried w/o debugger attached but reset is not taking place
2) Symbolic constants are correct
3) when I try to write 0x5fa0001 via debugger, the value is rolling back to 0x5FA
Thanks in advance
I'd use the memory dump window instead of the special one. Not sure what the debugger does under the hood.
