hey,
I wrote below code but I never get 'A' in output!!!!
I use Arduino uno to read data!
void SysTick_Handler(void){ i++; if(i==1000) i=0; } int main(){ RCC->AHB1ENR|=RCC_AHB1ENR_GPIOAEN; RCC->APB1ENR |=RCC_APB1ENR_USART2EN; // enable usart2 //PA2,PA3 GPIOA->MODER |=0xA0; // enable PA2,PA3 GPIOA->OSPEEDR |=0xA0; // set speed GPIOA->AFR[0]=0x7700; // set AFR7 USART2->CR1=0x2008; USART2->BRR=0x1117; SysTick_Config(168000); while(1){ USART2->DR='A'; } }
Is it a quiz? Do you want us to guess which controller you are using?
Anyway, you better ask this question in a forum related to Arduino or the controller you are using.
I just send "A" from stm32f407vg to Arduino uno! I cant go out for buy serial to usb converterand I use Arduino for read data!!!!
For the stm32 setup I recommend a stm32 forum.
Anyway, print the received byte in hex and also check errors on Arduino's serial port.
