Cortex M4 and ARM FIR Q15 Hardfault
Hi
I have tried to test CMSIS DSP FIR library in my STM32G474. Unfortunately after writing a simple test code, where i have prepared input signal and fir coefficients (by Matlab, verified) processor after executing arm_fir_q15 instruction goes to the HardFault. Im using newest DSP library from the Github. arm_mat.h 1.7.0, amr_fir_init_q15.c 1.6.0 and arm_fir_q15.c 1.6.0.
Its hard to catch where exacly processor goes to the debug (lots of clicking in debug step by step instruction execution) but what is strange for me that processor executes a code an function arm_fir_q15_1_8_mve from arm_fir_q15.c whith is not defined! (my IDE shoudnt compiled this). However when i removed this function and forced software to use standard arm_fir_q15 function , HardFault appears also. I have also tried older 1.5.1 version of amr_fir_q15.c but result is the same.
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>© Copyright (c) 2020 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
//#define ARM_MATH_CM4
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#include <math.h>
#include "arm_math.h"
#define ARM_MATH_DSP
#define TEST_LENGTH_SAMPLES  320
#define BLOCK_SIZE            32
#define NUM_TAPS              29
static q15_t signal_q15_in[TEST_LENGTH_SAMPLES] = {0,16436,19259,12778,12465,22935,31161,24333,7704,-2261
												 ,-0,2261,-7704,-24333,-31161,-22936,-12465,-12778,-19259,
												 -16436,-0,16436,19259,12778,12465,22935,31161,24333,7704,
												 -2261,-0,2261,-7704,-24333,-31161,-22936,-12465,-12778,
												 -19259,-16436,-0,16436,19259,12778,12465,22935,31161,
												 24333,7704,-2261,-0,2261,-7704,-24333,-31161,-22935,
												 -12465,-12778,-19259,-16436,-0,16436,19259,12778,12465,
												 22936,31161,24333,7704,-2261,-0,2261,-7704,-24333,-31161,
												 -22935,-12465,-12778,-19259,-16436,-0,16436,19259,12778,
												 12465,22936,31161,24333,7704,-2261,-0,2261,-7704,-24333,
												 -31161,-22936,-12465,-12778,-19259,-16436,-0,16436,19259,
												 12778,12465,22936,31161,24333,7704,-2261,0,2261,-7704,
												 -24333,-31161,-22936,-12465,-12778,-19259,-16436,-0,
												 16436,19259,12778,12465,22936,31161,24333,7704,-2261,
												 -16436,-0,16436,19259,12778,12465,22936,31161,24333,7704,
												 -2261,0,2261,-7704,-24333,-31161,-22936,-12465,-12778,-19259,
												 -2261,-0,2261,-7704,-24333,-31161,-22936,-12465,-12778,-19259,
												 -16436,-0,16436,19259,12778,12465,22935,31161,24333,7704,-2261,
												 0,2261,-7704,-24333,-31161,-22936,-12465,-12778,-19259,-16436,0,
												 16436,19259,12778,12465,22935,31161,24333,7704,-2261,-0,2261,
												 -7704,-24333,-31161,-22936,-12465,-12778,-19259,-16436,-0,16436,
												 19259,12778,12465,22935,31161,24333,7704,-2261,0,2261,-7704,-24333,
												 -31161,-22936,-12465,-12778,-19259,-16436,0,16436,19259,12778,12465,
												 22935,31161,24333,7704,-2261,-0,2261,-7704,-24333,-31161,-22936,-12465,
												 -12778,-19259,-16436,-0,16436,19259,12778,12465,22935,31161,24333,
												 7704,-2261,0,2261,-7704,-24333,-31161,-22936,-12465,-12778,-19259,
												 -16436,0,16436,19259,12778,12465,22935,31161,24333,7704,-2261,-0,
static q15_t signal_q15_out[TEST_LENGTH_SAMPLES];
static q15_t firStateQ15[BLOCK_SIZE + NUM_TAPS - 1];
static q15_t firCoeffs[NUM_TAPS] = {35, -23, -104, -138, 0,
		319, 543, 249, -657, -1543,
		-1268, 967, 4736, 8345, 9835,
		8345, 4736, 967, -1268, -1543,
		-657, 249, 543, 319, 0,
		-138, -104, -23, 35};
uint32_t blockSize = BLOCK_SIZE;
uint32_t numBlocks = TEST_LENGTH_SAMPLES/BLOCK_SIZE;
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef hlpuart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_LPUART1_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_LPUART1_UART_Init();
  /* USER CODE BEGIN 2 */
  uint32_t i;
  arm_fir_instance_q15 S;
  q15_t* inbufPtr_q15;
  q15_t* outbufPtr_q15;
  inbufPtr_q15 = &signal_q15_in[0];
  outbufPtr_q15 = &signal_q15_out[0];
  arm_fir_init_q15(&S, NUM_TAPS, (q15_t *)&firCoeffs[0], (q15_t *)&firStateQ15[0], blockSize);
  for(i=0; i < numBlocks; i++)
	arm_fir_q15(&S, inbufPtr_q15  + (i*blockSize), outbufPtr_q15+ (i*blockSize), blockSize);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  /** Configure the main internal regulator output voltage
  HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1_BOOST);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV4;
  RCC_OscInitStruct.PLL.PLLN = 85;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_8) != HAL_OK)
    Error_Handler();
  /** Initializes the peripherals clocks
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_LPUART1;
  PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    Error_Handler();
  * @brief LPUART1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN LPUART1_Init 0 */
  /* USER CODE END LPUART1_Init 0 */
  /* USER CODE BEGIN LPUART1_Init 1 */
  /* USER CODE END LPUART1_Init 1 */
  hlpuart1.Instance = LPUART1;
  hlpuart1.Init.BaudRate = 115200;
  hlpuart1.Init.WordLength = UART_WORDLENGTH_8B;
  hlpuart1.Init.StopBits = UART_STOPBITS_1;
  hlpuart1.Init.Parity = UART_PARITY_NONE;
  hlpuart1.Init.Mode = UART_MODE_TX_RX;
  hlpuart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  hlpuart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  hlpuart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&hlpuart1) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetTxFifoThreshold(&hlpuart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetRxFifoThreshold(&hlpuart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_DisableFifoMode(&hlpuart1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN LPUART1_Init 2 */
  /* USER CODE END LPUART1_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : LD2_Pin */
  GPIO_InitStruct.Pin = LD2_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(LD2_GPIO_Port, &GPIO_InitStruct);
  /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI15_10_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
