Dear Concern
I connected the CMSDK timer example with the Cortex - M0 processor. I have written exception handler for a timer in assembly code. After a certain moment interrupt is generated from the timer module in CMSDK. I see that the processor enters the exception handler for the first time and executes the handler and stays there. Please check the timer handler which basically sends a digit to a peripheral when triggered. The code is provided below. The processor does not return to the reset handler from the timer handler. I see that the processor when enters the timer handler for the first time responds to the interrupt and in the end of executing the timer handler provides the address like fffffff8. fffffff8,..fffffffc.....fffffffc...00000004 then gets stuck. The processor does not provide the other addresses. As a result, it does not go to reset handler hence does not respond to any peripherals. I am sharing the timer handler and reset handlers. Please help.
Reset_Handler PROC GLOBAL Reset_Handler ENTRY ; Setting the NVIC register LDR R1, =0xE000E400 ;Interrupt Priority Register LDR R0, =0x00000000 ;Priority: IRQ0: 0x00 STR R0, [R1] LDR R1, =0xE000E100 ;Interrupt Set Enable Register LDR R0, =0x00000001 ;Enable interrupt for timer STR R0, [R1] MOVS R0,#0x0; clearing the Primask to accept the interrupts MSR PRIMASK, R0 ; configure the timer LDR R1, =0x40001008 ;reload value to Timer MOVS R0, #0xFF STR R0, [R1] LDR R1, =0x40001000 ;control register value to Timer MOVS R0, #0x09 STR R0, [R1] ; apb led LDR R1, =0x40000000 ;Write to APB-LED with value with 0x25 MOVS R0, #0x35 STR R0, [R1] LDR R1, =0x20000000 ;Write to SRAM with value with 0x25 LDR R0, =0x25 STR R0, [R1] ; loop to keep processor awake so that it can receive interrupts AGAIN B AGAIN ENDP ;Timer_Handler Timer_Handler PROC EXPORT Timer_Handler LDR R1, =0x4000100C ;Clear Register MOVS R0, #0x01 STR R0, [R1] LDR R1, =0x40000000 ;Write to APB-LED with value with 0x25 MOVS R0, #0x25 STR R0, [R1] BX LR ENDP ALIGN 4 ; Align to a word boundary END
Besides posting code inline instead of using "insert->code" ...Is your stack setup correctly? (In RAM!)
:-) There should be a default "FAQ" for new users in this forum.
Absolutely - should be a "walk-through" of the features.
It's amazing that people who have grown up with the Internet seem to have such little clue how to actually use it.
Don't the schools teach this stuff?
Hi Mr. Bastian Schik, Thank you for your answer. I am new to this platform and I am connecting peripherals with the processor. I did not work with the stack set up before. Can you share any link or process flow to do this? Is it like that I have to declare the area for the stack at the beginning of the code?
Thank you so much. I am new to this platform. I will maintain it next time I post questions.
In the vector table, I reserved space like
__Vectors DCD 0x00003FFc ; 1K Internal Memory DCD Reset_Handler DCD 0 DCD 0... so on
It seems you are "building" your own SoC, so make sure there is really memory at this address. The address seems rather unusual for a Cortex-M.
Regarding examples, there are plenty outside.
Mezan1 said:I am new to this platform
It's the same on any other platform!
It would be the same if you were trying to present code in a word processor document.
See: www.avrfreaks.net/.../2477336
Dear Andy Neil, thanks for you suggestion. All I want to say I am sorry. Next time I will be careful.
Dear Bastian Schick
It helped me. Thanks for your support.
Thank you also for guiding me through this process. But I did not see this verify option here.
