Hey guys,
I have been exploring building PIC using the gcc toolchain and I think there is a bug.
I first build a shared library using
arm-none-eabi-gcc -shared -mcpu=cortex-m4 -mthumb -Wall -g -fPIC -fmessage-length=0 --specs=nosys.specs mylib.c -o libmylib.so
and then link to my code using the follwing
arm-none-eabi-gcc -x assembler-with-cpp -c -O0 -mcpu=cortex-m4 -mthumb -Wall -fmessage-length=0 -fPIC startup.S -o startup.o arm-none-eabi-gcc -c -mcpu=cortex-m4 -mthumb -Wall -g -fmessage-length=0 --specs=nosys.specs -fPIC main.c -o main.o arm-none-eabi-ld startup.o main.o -g -nostdlib -T./stm32_linker.ld -L. -lmylib -o main.elf
Full code is at https://github.com/rgujju/STM32-projects/tree/master/got_plt , generate the required code using 'make got_plt'. I have also attached the disassembly of the code at the end for convenience.
What I expect is the function call to <library_function> to go through the GOT and PLT and eventually go into the .dynamic section. I understand that i will have to build a dynamic linker for the actual call to <library_function> work but i just want to check if it runs till this point correctly first. But the code gives a fault at 0x800010c. The branch to the instruction at 0x800010c is from 0x8000126. The value of ip at 0x8000126 is 0x200000a0, hence the PC gets loaded with 0x800010c. The CFSR value after the fault is 0x00020001 which is IACCVIOL and INVSTATE. INVSTATE occurs when the last bit is not set to 1 for a thumb2 instruction. So I changed the 0x800010c to 0x800010d and it seems to work fine.
IACCVIOL
So my question is, is this actually a bug in gcc or am i doing something wrong?
Thanks a lot for your help.
EDIT: I am using arm gcc 9-2019-q4-major
EDIT: Added GBD output
From https://interrupt.memfault.com/blog/cortex-m-fault-debug
INVSTATE - Indicates the processor has tried to execute an instruction with an invalid Execution Program Status Register (EPSR) value. Among other things the ESPR tracks whether or not the processor is in thumb mode state. Instructions which use “interworking addresses”2 (bx & blx or ldr & ldm when loading a pc-relative value) must set bit[0] of the instruction to 1 as this is used to update ESPR.T. If this rule is violated, a INVSTATE exception will be generated. When writing C code, the compiler will take care of this automatically, but this is a common bug which can arise when hand-writing assembly.
INVSTATE
bx
blx
ldr
ldm
pc
bit[0]
ESPR.T
main.elf: file format elf32-littlearm Disassembly of section .vector_table: 08000000 <vtable>: 8000000: 20001000 andcs r1, r0, r0 8000004: 08000009 stmdaeq r0, {r0, r3} 08000008 <reset_handler>: 8000008: 480b ldr r0, [pc, #44] ; (8000038 <__main_loop+0x2>) 800000a: 4685 mov sp, r0 800000c: 2000 movs r0, #0 800000e: 490b ldr r1, [pc, #44] ; (800003c <__main_loop+0x6>) 8000010: 4a0b ldr r2, [pc, #44] ; (8000040 <__main_loop+0xa>) 8000012: 4b0c ldr r3, [pc, #48] ; (8000044 <__main_loop+0xe>) 8000014: e002 b.n 800001c <copy_sidata_loop> 08000016 <copy_sidata>: 8000016: 581c ldr r4, [r3, r0] 8000018: 500c str r4, [r1, r0] 800001a: 3004 adds r0, #4 0800001c <copy_sidata_loop>: 800001c: 1844 adds r4, r0, r1 800001e: 4294 cmp r4, r2 8000020: d3f9 bcc.n 8000016 <copy_sidata> 8000022: 2000 movs r0, #0 8000024: 4908 ldr r1, [pc, #32] ; (8000048 <__main_loop+0x12>) 8000026: 4a09 ldr r2, [pc, #36] ; (800004c <__main_loop+0x16>) 8000028: e001 b.n 800002e <reset_bss_loop> 0800002a <reset_bss>: 800002a: 6008 str r0, [r1, #0] 800002c: 3104 adds r1, #4 0800002e <reset_bss_loop>: 800002e: 4291 cmp r1, r2 8000030: d3fb bcc.n 800002a <reset_bss> 8000032: f000 b80d b.w 8000050 <main> 08000036 <__main_loop>: 8000036: e7fe b.n 8000036 <__main_loop> 8000038: 20001000 andcs r1, r0, r0 800003c: 20000000 andcs r0, r0, r0 8000040: 200000a4 andcs r0, r0, r4, lsr #1 8000044: 08000134 stmdaeq r0, {r2, r4, r5, r8} 8000048: 200000a4 andcs r0, r0, r4, lsr #1 800004c: 200000b0 strhcs r0, [r0], -r0 ; <UNPREDICTABLE> Disassembly of section .text: 08000050 <main>: unsigned int x; unsigned int y; unsigned int z; int main ( void ) { 8000050: b598 push {r3, r4, r7, lr} 8000052: af00 add r7, sp, #0 8000054: 4c09 ldr r4, [pc, #36] ; (800007c <main+0x2c>) 8000056: 447c add r4, pc x=7; 8000058: 4b09 ldr r3, [pc, #36] ; (8000080 <main+0x30>) 800005a: 58e3 ldr r3, [r4, r3] 800005c: 461a mov r2, r3 800005e: 2307 movs r3, #7 8000060: 6013 str r3, [r2, #0] y=8; 8000062: 4b08 ldr r3, [pc, #32] ; (8000084 <main+0x34>) 8000064: 58e3 ldr r3, [r4, r3] 8000066: 461a mov r2, r3 8000068: 2308 movs r3, #8 800006a: 6013 str r3, [r2, #0] z=library_function(77); 800006c: 204d movs r0, #77 ; 0x4d 800006e: f000 f855 bl 800011c <.plt+0x10> 8000072: 4602 mov r2, r0 8000074: 4b04 ldr r3, [pc, #16] ; (8000088 <main+0x38>) 8000076: 58e3 ldr r3, [r4, r3] 8000078: 601a str r2, [r3, #0] while(1){ 800007a: e7fe b.n 800007a <main+0x2a> 800007c: 1800002e stmdane r0, {r1, r2, r3, r5} 8000080: 00000000 andeq r0, r0, r0 8000084: 00000008 andeq r0, r0, r8 8000088: 00000004 andeq r0, r0, r4 Disassembly of section .interp: 0800008c <.interp>: 800008c: 7273752f rsbsvc r7, r3, #197132288 ; 0xbc00000 8000090: 62696c2f rsbvs r6, r9, #12032 ; 0x2f00 8000094: 2e646c2f cdpcs 12, 6, cr6, cr4, cr15, {1} 8000098: 312e6f73 ; <UNDEFINED> instruction: 0x312e6f73 800009c: Address 0x000000000800009c is out of bounds. Disassembly of section .dynsym: 080000a0 <.dynsym>: 80000a0: 00000000 andeq r0, r0, r0 80000a4: 00000000 andeq r0, r0, r0 80000a8: 00000000 andeq r0, r0, r0 80000ac: 00000000 andeq r0, r0, r0 80000b0: 0000000d andeq r0, r0, sp 80000b4: 00000000 andeq r0, r0, r0 80000b8: 00000000 andeq r0, r0, r0 80000bc: 00000012 andeq r0, r0, r2, lsl r0 80000c0: 0000001e andeq r0, r0, lr, lsl r0 80000c4: 08000051 stmdaeq r0, {r0, r4, r6} 80000c8: 0000003c andeq r0, r0, ip, lsr r0 80000cc: 00020012 andeq r0, r2, r2, lsl r0 Disassembly of section .dynstr: 080000d0 <.dynstr>: 80000d0: 62696c00 rsbvs r6, r9, #0, 24 80000d4: 696c796d stmdbvs ip!, {r0, r2, r3, r5, r6, r8, fp, ip, sp, lr}^ 80000d8: 6f732e62 svcvs 0x00732e62 80000dc: 62696c00 rsbvs r6, r9, #0, 24 80000e0: 79726172 ldmdbvc r2!, {r1, r4, r5, r6, r8, sp, lr}^ 80000e4: 6e75665f mrcvs 6, 3, r6, cr5, cr15, {2} 80000e8: 6f697463 svcvs 0x00697463 80000ec: 616d006e cmnvs sp, lr, rrx 80000f0: Address 0x00000000080000f0 is out of bounds. Disassembly of section .hash: 080000f4 <.hash>: 80000f4: 00000001 andeq r0, r0, r1 80000f8: 00000003 andeq r0, r0, r3 80000fc: 00000002 andeq r0, r0, r2 8000100: 00000000 andeq r0, r0, r0 8000104: 00000000 andeq r0, r0, r0 8000108: 00000001 andeq r0, r0, r1 Disassembly of section .plt: 0800010c <.plt>: 800010c: b500 push {lr} 800010e: f8df e008 ldr.w lr, [pc, #8] ; 8000118 <.plt+0xc> 8000112: 44fe add lr, pc 8000114: f85e ff08 ldr.w pc, [lr, #8]! 8000118: 17ffff7c ; <UNDEFINED> instruction: 0x17ffff7c 800011c: f64f 7c78 movw ip, #65400 ; 0xff78 8000120: f2c1 7cff movt ip, #6143 ; 0x17ff 8000124: 44fc add ip, pc 8000126: f8dc f000 ldr.w pc, [ip] 800012a: e7fd b.n 8000128 <.plt+0x1c> Disassembly of section .rel.dyn: 0800012c <.rel.dyn>: 800012c: 200000a0 andcs r0, r0, r0, lsr #1 8000130: 00000116 andeq r0, r0, r6, lsl r1 Disassembly of section .dynamic: 20000000 <_DYNAMIC>: 20000000: 00000001 andeq r0, r0, r1 20000004: 00000001 andeq r0, r0, r1 20000008: 00000004 andeq r0, r0, r4 2000000c: 080000f4 stmdaeq r0, {r2, r4, r5, r6, r7} 20000010: 00000005 andeq r0, r0, r5 20000014: 080000d0 stmdaeq r0, {r4, r6, r7} 20000018: 00000006 andeq r0, r0, r6 2000001c: 080000a0 stmdaeq r0, {r5, r7} 20000020: 0000000a andeq r0, r0, sl 20000024: 00000023 andeq r0, r0, r3, lsr #32 20000028: 0000000b andeq r0, r0, fp 2000002c: 00000010 andeq r0, r0, r0, lsl r0 20000030: 00000015 andeq r0, r0, r5, lsl r0 20000034: 00000000 andeq r0, r0, r0 20000038: 00000003 andeq r0, r0, r3 2000003c: 20000094 mulcs r0, r4, r0 20000040: 00000002 andeq r0, r0, r2 20000044: 00000008 andeq r0, r0, r8 20000048: 00000014 andeq r0, r0, r4, lsl r0 2000004c: 00000011 andeq r0, r0, r1, lsl r0 20000050: 00000017 andeq r0, r0, r7, lsl r0 20000054: 0800012c stmdaeq r0, {r2, r3, r5, r8} 20000058: 00000000 andeq r0, r0, r0 2000005c: 00000000 andeq r0, r0, r0 20000060: 00000000 andeq r0, r0, r0 20000064: 00000000 andeq r0, r0, r0 20000068: 00000000 andeq r0, r0, r0 2000006c: 00000000 andeq r0, r0, r0 20000070: 00000000 andeq r0, r0, r0 20000074: 00000000 andeq r0, r0, r0 20000078: 00000000 andeq r0, r0, r0 2000007c: 00000000 andeq r0, r0, r0 20000080: 00000000 andeq r0, r0, r0 20000084: 00000000 andeq r0, r0, r0 Disassembly of section .got: 20000088 <.got>: 20000088: 200000a4 andcs r0, r0, r4, lsr #1 2000008c: 200000a8 andcs r0, r0, r8, lsr #1 20000090: 200000ac andcs r0, r0, ip, lsr #1 Disassembly of section .got.plt: 20000094 <_GLOBAL_OFFSET_TABLE_>: 20000094: 20000000 andcs r0, r0, r0 20000098: 00000000 andeq r0, r0, r0 2000009c: 00000000 andeq r0, r0, r0 200000a0: 0800010c stmdaeq r0, {r2, r3, r8} Disassembly of section .bss: 200000a4 <x>: unsigned int x; 200000a4: 00000000 andeq r0, r0, r0 200000a8 <z>: unsigned int z; 200000a8: 00000000 andeq r0, r0, r0 200000ac <y>: unsigned int y; 200000ac: 00000000 andeq r0, r0, r0 Disassembly of section .dynamic_allocations: 200000b0 <_ssystem_ram>: 200000b0: 00000000 andeq r0, r0, r0 200000b4: 00000000 andeq r0, r0, r0 200000b8: 00000000 andeq r0, r0, r0 200000bc: 00000000 andeq r0, r0, r0 200000c0: 00000000 andeq r0, r0, r0 200000c4: 00000000 andeq r0, r0, r0 200000c8: 00000000 andeq r0, r0, r0 200000cc: 00000000 andeq r0, r0, r0 200000d0: 00000000 andeq r0, r0, r0 200000d4: 00000000 andeq r0, r0, r0 200000d8: 00000000 andeq r0, r0, r0 200000dc: 00000000 andeq r0, r0, r0 200000e0: 00000000 andeq r0, r0, r0 200000e4: 00000000 andeq r0, r0, r0 200000e8: 00000000 andeq r0, r0, r0 200000ec: 00000000 andeq r0, r0, r0 200000f0: 00000000 andeq r0, r0, r0 200000f4: 00000000 andeq r0, r0, r0 200000f8: 00000000 andeq r0, r0, r0 200000fc: 00000000 andeq r0, r0, r0 20000100: 00000000 andeq r0, r0, r0 20000104: 00000000 andeq r0, r0, r0 20000108: 00000000 andeq r0, r0, r0 2000010c: 00000000 andeq r0, r0, r0 20000110: 00000000 andeq r0, r0, r0 20000114: 00000000 andeq r0, r0, r0 20000118: 00000000 andeq r0, r0, r0 2000011c: 00000000 andeq r0, r0, r0 20000120: 00000000 andeq r0, r0, r0 20000124: 00000000 andeq r0, r0, r0 20000128: 00000000 andeq r0, r0, r0 2000012c: 00000000 andeq r0, r0, r0 20000130: 00000000 andeq r0, r0, r0 20000134: 00000000 andeq r0, r0, r0 20000138: 00000000 andeq r0, r0, r0 2000013c: 00000000 andeq r0, r0, r0 20000140: 00000000 andeq r0, r0, r0 20000144: 00000000 andeq r0, r0, r0 20000148: 00000000 andeq r0, r0, r0 2000014c: 00000000 andeq r0, r0, r0 20000150: 00000000 andeq r0, r0, r0 20000154: 00000000 andeq r0, r0, r0 20000158: 00000000 andeq r0, r0, r0 2000015c: 00000000 andeq r0, r0, r0 20000160: 00000000 andeq r0, r0, r0 20000164: 00000000 andeq r0, r0, r0 20000168: 00000000 andeq r0, r0, r0 2000016c: 00000000 andeq r0, r0, r0 20000170: 00000000 andeq r0, r0, r0 20000174: 00000000 andeq r0, r0, r0 20000178: 00000000 andeq r0, r0, r0 2000017c: 00000000 andeq r0, r0, r0 20000180: 00000000 andeq r0, r0, r0 20000184: 00000000 andeq r0, r0, r0 20000188: 00000000 andeq r0, r0, r0 2000018c: 00000000 andeq r0, r0, r0 20000190: 00000000 andeq r0, r0, r0 20000194: 00000000 andeq r0, r0, r0 20000198: 00000000 andeq r0, r0, r0 2000019c: 00000000 andeq r0, r0, r0 200001a0: 00000000 andeq r0, r0, r0 200001a4: 00000000 andeq r0, r0, r0 200001a8: 00000000 andeq r0, r0, r0 200001ac: 00000000 andeq r0, r0, r0 200001b0: 00000000 andeq r0, r0, r0 200001b4: 00000000 andeq r0, r0, r0 200001b8: 00000000 andeq r0, r0, r0 200001bc: 00000000 andeq r0, r0, r0 200001c0: 00000000 andeq r0, r0, r0 200001c4: 00000000 andeq r0, r0, r0 200001c8: 00000000 andeq r0, r0, r0 200001cc: 00000000 andeq r0, r0, r0 200001d0: 00000000 andeq r0, r0, r0 200001d4: 00000000 andeq r0, r0, r0 200001d8: 00000000 andeq r0, r0, r0 200001dc: 00000000 andeq r0, r0, r0 200001e0: 00000000 andeq r0, r0, r0 200001e4: 00000000 andeq r0, r0, r0 200001e8: 00000000 andeq r0, r0, r0 200001ec: 00000000 andeq r0, r0, r0 200001f0: 00000000 andeq r0, r0, r0 200001f4: 00000000 andeq r0, r0, r0 200001f8: 00000000 andeq r0, r0, r0 200001fc: 00000000 andeq r0, r0, r0 20000200: 00000000 andeq r0, r0, r0 20000204: 00000000 andeq r0, r0, r0 20000208: 00000000 andeq r0, r0, r0 2000020c: 00000000 andeq r0, r0, r0 20000210: 00000000 andeq r0, r0, r0 20000214: 00000000 andeq r0, r0, r0 20000218: 00000000 andeq r0, r0, r0 2000021c: 00000000 andeq r0, r0, r0 20000220: 00000000 andeq r0, r0, r0 20000224: 00000000 andeq r0, r0, r0 20000228: 00000000 andeq r0, r0, r0 2000022c: 00000000 andeq r0, r0, r0 20000230: 00000000 andeq r0, r0, r0 20000234: 00000000 andeq r0, r0, r0 20000238: 00000000 andeq r0, r0, r0 2000023c: 00000000 andeq r0, r0, r0 20000240: 00000000 andeq r0, r0, r0 20000244: 00000000 andeq r0, r0, r0 20000248: 00000000 andeq r0, r0, r0 2000024c: 00000000 andeq r0, r0, r0 20000250: 00000000 andeq r0, r0, r0 20000254: 00000000 andeq r0, r0, r0 20000258: 00000000 andeq r0, r0, r0 2000025c: 00000000 andeq r0, r0, r0 20000260: 00000000 andeq r0, r0, r0 20000264: 00000000 andeq r0, r0, r0 20000268: 00000000 andeq r0, r0, r0 2000026c: 00000000 andeq r0, r0, r0 20000270: 00000000 andeq r0, r0, r0 20000274: 00000000 andeq r0, r0, r0 20000278: 00000000 andeq r0, r0, r0 2000027c: 00000000 andeq r0, r0, r0 20000280: 00000000 andeq r0, r0, r0 20000284: 00000000 andeq r0, r0, r0 20000288: 00000000 andeq r0, r0, r0 2000028c: 00000000 andeq r0, r0, r0 20000290: 00000000 andeq r0, r0, r0 20000294: 00000000 andeq r0, r0, r0 20000298: 00000000 andeq r0, r0, r0 2000029c: 00000000 andeq r0, r0, r0 200002a0: 00000000 andeq r0, r0, r0 200002a4: 00000000 andeq r0, r0, r0 200002a8: 00000000 andeq r0, r0, r0 200002ac: 00000000 andeq r0, r0, r0 200002b0: 00000000 andeq r0, r0, r0 200002b4: 00000000 andeq r0, r0, r0 200002b8: 00000000 andeq r0, r0, r0 200002bc: 00000000 andeq r0, r0, r0 200002c0: 00000000 andeq r0, r0, r0 200002c4: 00000000 andeq r0, r0, r0 200002c8: 00000000 andeq r0, r0, r0 200002cc: 00000000 andeq r0, r0, r0 200002d0: 00000000 andeq r0, r0, r0 200002d4: 00000000 andeq r0, r0, r0 200002d8: 00000000 andeq r0, r0, r0 200002dc: 00000000 andeq r0, r0, r0 200002e0: 00000000 andeq r0, r0, r0 200002e4: 00000000 andeq r0, r0, r0 200002e8: 00000000 andeq r0, r0, r0 200002ec: 00000000 andeq r0, r0, r0 200002f0: 00000000 andeq r0, r0, r0 200002f4: 00000000 andeq r0, r0, r0 200002f8: 00000000 andeq r0, r0, r0 200002fc: 00000000 andeq r0, r0, r0 20000300: 00000000 andeq r0, r0, r0 20000304: 00000000 andeq r0, r0, r0 20000308: 00000000 andeq r0, r0, r0 2000030c: 00000000 andeq r0, r0, r0 20000310: 00000000 andeq r0, r0, r0 20000314: 00000000 andeq r0, r0, r0 20000318: 00000000 andeq r0, r0, r0 2000031c: 00000000 andeq r0, r0, r0 20000320: 00000000 andeq r0, r0, r0 20000324: 00000000 andeq r0, r0, r0 20000328: 00000000 andeq r0, r0, r0 2000032c: 00000000 andeq r0, r0, r0 20000330: 00000000 andeq r0, r0, r0 20000334: 00000000 andeq r0, r0, r0 20000338: 00000000 andeq r0, r0, r0 2000033c: 00000000 andeq r0, r0, r0 20000340: 00000000 andeq r0, r0, r0 20000344: 00000000 andeq r0, r0, r0 20000348: 00000000 andeq r0, r0, r0 2000034c: 00000000 andeq r0, r0, r0 20000350: 00000000 andeq r0, r0, r0 20000354: 00000000 andeq r0, r0, r0 20000358: 00000000 andeq r0, r0, r0 2000035c: 00000000 andeq r0, r0, r0 20000360: 00000000 andeq r0, r0, r0 20000364: 00000000 andeq r0, r0, r0 20000368: 00000000 andeq r0, r0, r0 2000036c: 00000000 andeq r0, r0, r0 20000370: 00000000 andeq r0, r0, r0 20000374: 00000000 andeq r0, r0, r0 20000378: 00000000 andeq r0, r0, r0 2000037c: 00000000 andeq r0, r0, r0 20000380: 00000000 andeq r0, r0, r0 20000384: 00000000 andeq r0, r0, r0 20000388: 00000000 andeq r0, r0, r0 2000038c: 00000000 andeq r0, r0, r0 20000390: 00000000 andeq r0, r0, r0 20000394: 00000000 andeq r0, r0, r0 20000398: 00000000 andeq r0, r0, r0 2000039c: 00000000 andeq r0, r0, r0 200003a0: 00000000 andeq r0, r0, r0 200003a4: 00000000 andeq r0, r0, r0 200003a8: 00000000 andeq r0, r0, r0 200003ac: 00000000 andeq r0, r0, r0 200003b0: 00000000 andeq r0, r0, r0 200003b4: 00000000 andeq r0, r0, r0 200003b8: 00000000 andeq r0, r0, r0 200003bc: 00000000 andeq r0, r0, r0 200003c0: 00000000 andeq r0, r0, r0 200003c4: 00000000 andeq r0, r0, r0 200003c8: 00000000 andeq r0, r0, r0 200003cc: 00000000 andeq r0, r0, r0 200003d0: 00000000 andeq r0, r0, r0 200003d4: 00000000 andeq r0, r0, r0 200003d8: 00000000 andeq r0, r0, r0 200003dc: 00000000 andeq r0, r0, r0 200003e0: 00000000 andeq r0, r0, r0 200003e4: 00000000 andeq r0, r0, r0 200003e8: 00000000 andeq r0, r0, r0 200003ec: 00000000 andeq r0, r0, r0 200003f0: 00000000 andeq r0, r0, r0 200003f4: 00000000 andeq r0, r0, r0 200003f8: 00000000 andeq r0, r0, r0 200003fc: 00000000 andeq r0, r0, r0 20000400: 00000000 andeq r0, r0, r0 20000404: 00000000 andeq r0, r0, r0 20000408: 00000000 andeq r0, r0, r0 2000040c: 00000000 andeq r0, r0, r0 20000410: 00000000 andeq r0, r0, r0 20000414: 00000000 andeq r0, r0, r0 20000418: 00000000 andeq r0, r0, r0 2000041c: 00000000 andeq r0, r0, r0 20000420: 00000000 andeq r0, r0, r0 20000424: 00000000 andeq r0, r0, r0 20000428: 00000000 andeq r0, r0, r0 2000042c: 00000000 andeq r0, r0, r0 20000430: 00000000 andeq r0, r0, r0 20000434: 00000000 andeq r0, r0, r0 20000438: 00000000 andeq r0, r0, r0 2000043c: 00000000 andeq r0, r0, r0 20000440: 00000000 andeq r0, r0, r0 20000444: 00000000 andeq r0, r0, r0 20000448: 00000000 andeq r0, r0, r0 2000044c: 00000000 andeq r0, r0, r0 20000450: 00000000 andeq r0, r0, r0 20000454: 00000000 andeq r0, r0, r0 20000458: 00000000 andeq r0, r0, r0 2000045c: 00000000 andeq r0, r0, r0 20000460: 00000000 andeq r0, r0, r0 20000464: 00000000 andeq r0, r0, r0 20000468: 00000000 andeq r0, r0, r0 2000046c: 00000000 andeq r0, r0, r0 20000470: 00000000 andeq r0, r0, r0 20000474: 00000000 andeq r0, r0, r0 20000478: 00000000 andeq r0, r0, r0 2000047c: 00000000 andeq r0, r0, r0 20000480: 00000000 andeq r0, r0, r0 20000484: 00000000 andeq r0, r0, r0 20000488: 00000000 andeq r0, r0, r0 2000048c: 00000000 andeq r0, r0, r0 20000490: 00000000 andeq r0, r0, r0 20000494: 00000000 andeq r0, r0, r0 20000498: 00000000 andeq r0, r0, r0 2000049c: 00000000 andeq r0, r0, r0 200004a0: 00000000 andeq r0, r0, r0 200004a4: 00000000 andeq r0, r0, r0 200004a8: 00000000 andeq r0, r0, r0 200004ac: 00000000 andeq r0, r0, r0 Disassembly of section .ARM.attributes: 00000000 <.ARM.attributes>: 0: 00002e41 andeq r2, r0, r1, asr #28 4: 61656100 cmnvs r5, r0, lsl #2 8: 01006962 tsteq r0, r2, ror #18 c: 00000024 andeq r0, r0, r4, lsr #32 10: 726f4305 rsbvc r4, pc, #335544320 ; 0x14000000 14: 2d786574 cfldr64cs mvdx6, [r8, #-464]! ; 0xfffffe30 18: 0600344d streq r3, [r0], -sp, asr #8 1c: 094d070d stmdbeq sp, {r0, r2, r3, r8, r9, sl}^ 20: 14041202 strne r1, [r4], #-514 ; 0xfffffdfe 24: 17011501 strne r1, [r1, -r1, lsl #10] 28: 1a011803 bne 4603c <_Min_Leftover_RAM+0x45c3c> 2c: Address 0x000000000000002c is out of bounds. Disassembly of section .comment: 00000000 <.comment>: 0: 3a434347 bcc 10d0d24 <_Min_Leftover_RAM+0x10d0924> 4: 4e472820 cdpmi 8, 4, cr2, cr7, cr0, {1} 8: 6f542055 svcvs 0x00542055 c: 20736c6f rsbscs r6, r3, pc, ror #24 10: 20726f66 rsbscs r6, r2, r6, ror #30 14: 206d7241 rsbcs r7, sp, r1, asr #4 18: 65626d45 strbvs r6, [r2, #-3397]! ; 0xfffff2bb 1c: 64656464 strbtvs r6, [r5], #-1124 ; 0xfffffb9c 20: 6f725020 svcvs 0x00725020 24: 73736563 cmnvc r3, #415236096 ; 0x18c00000 28: 2073726f rsbscs r7, r3, pc, ror #4 2c: 30322d39 eorscc r2, r2, r9, lsr sp 30: 712d3931 ; <UNDEFINED> instruction: 0x712d3931 34: 616d2d34 cmnvs sp, r4, lsr sp 38: 29726f6a ldmdbcs r2!, {r1, r3, r5, r6, r8, r9, sl, fp, sp, lr}^ 3c: 322e3920 eorcc r3, lr, #32, 18 ; 0x80000 40: 3220312e eorcc r3, r0, #-2147483637 ; 0x8000000b 44: 31393130 teqcc r9, r0, lsr r1 48: 20353230 eorscs r3, r5, r0, lsr r2 4c: 6c657228 sfmvs f7, 2, [r5], #-160 ; 0xffffff60 50: 65736165 ldrbvs r6, [r3, #-357]! ; 0xfffffe9b 54: 415b2029 cmpmi fp, r9, lsr #32 58: 612f4d52 ; <UNDEFINED> instruction: 0x612f4d52 5c: 392d6d72 pushcc {r1, r4, r5, r6, r8, sl, fp, sp, lr} 60: 6172622d cmnvs r2, sp, lsr #4 64: 2068636e rsbcs r6, r8, lr, ror #6 68: 69766572 ldmdbvs r6!, {r1, r4, r5, r6, r8, sl, sp, lr}^ 6c: 6e6f6973 ; <UNDEFINED> instruction: 0x6e6f6973 70: 37373220 ldrcc r3, [r7, -r0, lsr #4]! 74: 5d393935 ; <UNDEFINED> instruction: 0x5d393935 78: Address 0x0000000000000078 is out of bounds. Disassembly of section .debug_info: 00000000 <.debug_info>: 0: 00000076 andeq r0, r0, r6, ror r0 4: 00000004 andeq r0, r0, r4 8: 01040000 mrseq r0, (UNDEF: 4) c: 00000000 andeq r0, r0, r0 10: 0000cc0c andeq ip, r0, ip, lsl #24 14: 00009900 andeq r9, r0, r0, lsl #18 18: 00005000 andeq r5, r0, r0 1c: 00003c08 andeq r3, r0, r8, lsl #24 20: 00000000 andeq r0, r0, r0 24: 00780200 rsbseq r0, r8, r0, lsl #4 28: 350e0601 strcc r0, [lr, #-1537] ; 0xfffff9ff 2c: 05000000 streq r0, [r0, #-0] 30: 0000a403 andeq sl, r0, r3, lsl #8 34: 07040320 streq r0, [r4, -r0, lsr #6] 38: 000000d3 ldrdeq r0, [r0], -r3 3c: 01007902 tsteq r0, r2, lsl #18 40: 00350e07 eorseq r0, r5, r7, lsl #28 44: 03050000 movweq r0, #20480 ; 0x5000 48: 200000ac andcs r0, r0, ip, lsr #1 4c: 01007a02 tsteq r0, r2, lsl #20 50: 00350e08 eorseq r0, r5, r8, lsl #28 54: 03050000 movweq r0, #20480 ; 0x5000 58: 200000a8 andcs r0, r0, r8, lsr #1 5c: 0000e004 andeq lr, r0, r4 60: 050a0100 streq r0, [sl, #-256] ; 0xffffff00 64: 00000072 andeq r0, r0, r2, ror r0 68: 08000050 stmdaeq r0, {r4, r6} 6c: 0000003c andeq r0, r0, ip, lsr r0 70: 04059c01 streq r9, [r5], #-3073 ; 0xfffff3ff 74: 746e6905 strbtvc r6, [lr], #-2309 ; 0xfffff6fb 78: Address 0x0000000000000078 is out of bounds. Disassembly of section .debug_abbrev: 00000000 <.debug_abbrev>: 0: 25011101 strcs r1, [r1, #-257] ; 0xfffffeff 4: 030b130e movweq r1, #45838 ; 0xb30e 8: 110e1b0e tstne lr, lr, lsl #22 c: 10061201 andne r1, r6, r1, lsl #4 10: 02000017 andeq r0, r0, #23 14: 08030034 stmdaeq r3, {r2, r4, r5} 18: 0b3b0b3a bleq ec2d08 <_Min_Leftover_RAM+0xec2908> 1c: 13490b39 movtne r0, #39737 ; 0x9b39 20: 1802193f stmdane r2, {r0, r1, r2, r3, r4, r5, r8, fp, ip} 24: 24030000 strcs r0, [r3], #-0 28: 3e0b0b00 vmlacc.f64 d0, d11, d0 2c: 000e030b andeq r0, lr, fp, lsl #6 30: 002e0400 eoreq r0, lr, r0, lsl #8 34: 0e03193f ; <UNDEFINED> instruction: 0x0e03193f 38: 0b3b0b3a bleq ec2d28 <_Min_Leftover_RAM+0xec2928> 3c: 19270b39 stmdbne r7!, {r0, r3, r4, r5, r8, r9, fp} 40: 01111349 tsteq r1, r9, asr #6 44: 18400612 stmdane r0, {r1, r4, r9, sl}^ 48: 00194296 mulseq r9, r6, r2 4c: 00240500 eoreq r0, r4, r0, lsl #10 50: 0b3e0b0b bleq f82c84 <_Min_Leftover_RAM+0xf82884> 54: 00000803 andeq r0, r0, r3, lsl #16 58: Address 0x0000000000000058 is out of bounds. Disassembly of section .debug_aranges: 00000000 <.debug_aranges>: 0: 0000001c andeq r0, r0, ip, lsl r0 4: 00000002 andeq r0, r0, r2 8: 00040000 andeq r0, r4, r0 c: 00000000 andeq r0, r0, r0 10: 08000050 stmdaeq r0, {r4, r6} 14: 0000003c andeq r0, r0, ip, lsr r0 18: 00000000 andeq r0, r0, r0 1c: 00000000 andeq r0, r0, r0 Disassembly of section .debug_line: 00000000 <.debug_line>: 0: 00000045 andeq r0, r0, r5, asr #32 4: 001d0003 andseq r0, sp, r3 8: 01020000 mrseq r0, (UNDEF: 2) c: 000d0efb strdeq r0, [sp], -fp 10: 01010101 tsteq r1, r1, lsl #2 14: 01000000 mrseq r0, (UNDEF: 0) 18: 00010000 andeq r0, r1, r0 1c: 6e69616d powvsez f6, f1, #5.0 20: 0000632e andeq r6, r0, lr, lsr #6 24: 05000000 streq r0, [r0, #-0] 28: 02050001 andeq r0, r5, #1 2c: 08000050 stmdaeq r0, {r4, r6} 30: 05010a03 streq r0, [r1, #-2563] ; 0xfffff5fd 34: 05594b03 ldrbeq r4, [r9, #-2819] ; 0xfffff4fd 38: 03055904 movweq r5, #22788 ; 0x5904 3c: 0007054a andeq r0, r7, sl, asr #10 40: 3e010402 cdpcc 4, 0, cr0, cr1, cr2, {0} 44: 01000902 tsteq r0, r2, lsl #18 48: Address 0x0000000000000048 is out of bounds. Disassembly of section .debug_str: 00000000 <.debug_str>: 0: 20554e47 subscs r4, r5, r7, asr #28 4: 20373143 eorscs r3, r7, r3, asr #2 8: 2e322e39 mrccs 14, 1, r2, cr2, cr9, {1} c: 30322031 eorscc r2, r2, r1, lsr r0 10: 30313931 eorscc r3, r1, r1, lsr r9 14: 28203532 stmdacs r0!, {r1, r4, r5, r8, sl, ip, sp} 18: 656c6572 strbvs r6, [ip, #-1394]! ; 0xfffffa8e 1c: 29657361 stmdbcs r5!, {r0, r5, r6, r8, r9, ip, sp, lr}^ 20: 52415b20 subpl r5, r1, #32, 22 ; 0x8000 24: 72612f4d rsbvc r2, r1, #308 ; 0x134 28: 2d392d6d ldccs 13, cr2, [r9, #-436]! ; 0xfffffe4c 2c: 6e617262 cdpvs 2, 6, cr7, cr1, cr2, {3} 30: 72206863 eorvc r6, r0, #6488064 ; 0x630000 34: 73697665 cmnvc r9, #105906176 ; 0x6500000 38: 206e6f69 rsbcs r6, lr, r9, ror #30 3c: 35373732 ldrcc r3, [r7, #-1842]! ; 0xfffff8ce 40: 205d3939 subscs r3, sp, r9, lsr r9 44: 70636d2d rsbvc r6, r3, sp, lsr #26 48: 6f633d75 svcvs 0x00633d75 4c: 78657472 stmdavc r5!, {r1, r4, r5, r6, sl, ip, sp, lr}^ 50: 20346d2d eorscs r6, r4, sp, lsr #26 54: 68746d2d ldmdavs r4!, {r0, r2, r3, r5, r8, sl, fp, sp, lr}^ 58: 20626d75 rsbcs r6, r2, r5, ror sp 5c: 6c666d2d stclvs 13, cr6, [r6], #-180 ; 0xffffff4c 60: 2d74616f ldfcse f6, [r4, #-444]! ; 0xfffffe44 64: 3d696261 sfmcc f6, 2, [r9, #-388]! ; 0xfffffe7c 68: 74666f73 strbtvc r6, [r6], #-3955 ; 0xfffff08d 6c: 616d2d20 cmnvs sp, r0, lsr #26 70: 3d686372 stclcc 3, cr6, [r8, #-456]! ; 0xfffffe38 74: 766d7261 strbtvc r7, [sp], -r1, ror #4 78: 6d2d6537 cfstr32vs mvfx6, [sp, #-220]! ; 0xffffff24 7c: 20672d20 rsbcs r2, r7, r0, lsr #26 80: 656d662d strbvs r6, [sp, #-1581]! ; 0xfffff9d3 84: 67617373 ; <UNDEFINED> instruction: 0x67617373 88: 656c2d65 strbvs r2, [ip, #-3429]! ; 0xfffff29b 8c: 6874676e ldmdavs r4!, {r1, r2, r3, r5, r6, r8, r9, sl, sp, lr}^ 90: 2d20303d stccs 0, cr3, [r0, #-244]! ; 0xffffff0c 94: 43495066 movtmi r5, #36966 ; 0x9066 98: 6f682f00 svcvs 0x00682f00 9c: 722f656d eorvc r6, pc, #457179136 ; 0x1b400000 a0: 7469686f strbtvc r6, [r9], #-2159 ; 0xfffff791 a4: 636f442f cmnvs pc, #788529152 ; 0x2f000000 a8: 6e656d75 mcrvs 13, 3, r6, cr5, cr5, {3} ac: 532f7374 ; <UNDEFINED> instruction: 0x532f7374 b0: 32334d54 eorscc r4, r3, #84, 26 ; 0x1500 b4: 4d54532f ldclmi 3, cr5, [r4, #-188] ; 0xffffff44 b8: 702d3233 eorvc r3, sp, r3, lsr r2 bc: 656a6f72 strbvs r6, [sl, #-3954]! ; 0xfffff08e c0: 2f737463 svccs 0x00737463 c4: 5f746f67 svcpl 0x00746f67 c8: 00746c70 rsbseq r6, r4, r0, ror ip cc: 6e69616d powvsez f6, f1, #5.0 d0: 7500632e strvc r6, [r0, #-814] ; 0xfffffcd2 d4: 6769736e strbvs r7, [r9, -lr, ror #6]! d8: 2064656e rsbcs r6, r4, lr, ror #10 dc: 00746e69 rsbseq r6, r4, r9, ror #28 e0: 6e69616d powvsez f6, f1, #5.0 e4: Address 0x00000000000000e4 is out of bounds. Disassembly of section .debug_frame: 00000000 <.debug_frame>: 0: 0000000c andeq r0, r0, ip 4: ffffffff ; <UNDEFINED> instruction: 0xffffffff 8: 7c020001 stcvc 0, cr0, [r2], {1} c: 000d0c0e andeq r0, sp, lr, lsl #24 10: 0000001c andeq r0, r0, ip, lsl r0 14: 00000000 andeq r0, r0, r0 18: 08000050 stmdaeq r0, {r4, r6} 1c: 0000003c andeq r0, r0, ip, lsr r0 20: 83100e41 tsthi r0, #1040 ; 0x410 24: 87038404 strhi r8, [r3, -r4, lsl #8] 28: 41018e02 tstmi r1, r2, lsl #28 2c: 0000070d andeq r0, r0, sp, lsl #14
. . . 0x08000068 13 y=8; (gdb) si 0x0800006a 13 y=8; (gdb) si 14 z=library_function(77); (gdb) si 0x0800006e 14 z=library_function(77); (gdb) si 0x0800011c in ?? () (gdb) si 0x08000120 in ?? () (gdb) si 0x08000124 in ?? () (gdb) si 0x08000126 in ?? () (gdb) si 0x0800010c in ?? () (gdb) info registers r0 0x4d 77 r1 0x200000b0 536871088 r2 0x200000ac 536871084 r3 0x8 8 r4 0x20000088 536871048 r5 0x0 0 r6 0x0 0 r7 0x20000ff0 536874992 r8 0x0 0 r9 0x0 0 r10 0x0 0 r11 0x0 0 r12 0x200000a0 536871072 sp 0x20000ff0 0x20000ff0 lr 0x8000073 134217843 pc 0x800010c 0x800010c xpsr 0x20000000 536870912 msp 0x20000ff0 0x20000ff0 psp 0x0 0x0 control 0x0 0 '\000' faultmask 0x0 0 '\000' basepri 0x0 0 '\000' primask 0x0 0 '\000' fpscr 0x0 0 (gdb) si 0x490b2000 in ?? () (gdb) info registers r0 0x4d 77 r1 0x200000b0 536871088 r2 0x200000ac 536871084 r3 0x8 8 r4 0x20000088 536871048 r5 0x0 0 r6 0x0 0 r7 0x20000ff0 536874992 r8 0x0 0 r9 0x0 0 r10 0x0 0 r11 0x0 0 r12 0x200000a0 536871072 sp 0x20000fd0 0x20000fd0 lr 0xfffffff9 -7 pc 0x490b2000 0x490b2000 xpsr 0x20000003 536870915 msp 0x20000fd0 0x20000fd0 psp 0x0 0x0 control 0x0 0 '\000' faultmask 0x0 0 '\000' basepri 0x0 0 '\000' primask 0x0 0 '\000' fpscr 0x0 0 (gdb) quit A debugging session is active. Inferior 1 [Remote target] will be killed. Quit anyway? (y or n) y Remote connection closed
Thumb2-only dynamic-linking support was added/augmented under this bug. It has been reopened to investigate the problem described in this topic.
