I'm stepping & cycle checking with the DWT counter, on CM4
Question why is the second LDR here is 6 cycles, Is it because of flash vs SRAM ? And is Flash read always 6 cycles ?
And , is it in the processor cycles, not some slower bus-cycles, to calculate actual time taken .... [bah, more questions ...]
131 cycles_ave /= N; <-- N = 2001000966: 683B ldr r3, [r7] <-- ok, nice 2 cycles , R7 contains SRAM address (the running counter ..)01000968: 4A0D ldr r2, [pc, #0x34] <--- 6 cycles here .. .. pc+x34 = 010009A2 is flash ... Ok, my constant N load ..?0100096a: FBA22303 umull r2, r3, r2, r30100096e: 091B lsrs r3, r3, #401000970: 603B str r3, [r7]...........010009a0: CCCD ldm r4!, {r0, r2, r3, r6, r7} <---- this is weird, so above it loads 0xCCCCCCCD into r2 ( ??? I sort of, hoped to see a 20/x14 somewhere .. )010009a2: CCCC ldm r4!, {r2, r3, r6, r7}............
Overall , of course, it generates correct result, but I'm lost as to what's it doing. Some compiler magic translating to me ..
42Bastian Schick Andy Neil:
I'm reading CM4 tech reference manual, http://infocenter.arm.com/help/topic/com.arm.doc.ddi0439b/DDI0439B_cortex_m4_r0p0_trm.pdf
Again, sorry c&p:
Table 3-1
Word LDR Rd, [Rn, op2] 2 cycles (note b)
Lets ignore that b note, about sequential LDRs.
If op2 is Rm - another register to add to Rn - how can LDR be anything less than 3 cycles? When is Rn + Rm , the address, is calculated?
ARM7TDMI spec shows LDR as a 3 cycle op. How / what changed to ARMv7m to make it 2 cycles , and seems, avoid the need for cycle to calculate address?
d.ry said:ARM7TDMI spec shows LDR as a 3 cycle op. How / what changed to ARMv7m to make it 2 cycles , and seems, avoid the need for cycle to calculate address?
You should address this question to the designers of the core.
