Debugger-based Firmware Test Framework
Hi all.
I'm currently working on a Python-based framework for on-target firmware testing of firmware of Cortex-M MCU systems. The approach is heavily based on the use of the debug probe to perform unit as well as system tests.
The framework I have in mind allows us to do
  • firmware testing without modifications for testing (i.e., not test code compiled into the firmware)
  • firmware component testing without mocking of, e.g., peripherals
  • firmware testing with selective injection of data into the execution
  • firmware testing on the original target device
  • firmware testing using the original compiler
The tests themselves are implemented in Python and are executed on a host PC which also gives you full accesses to whatever equipment you already have available for providing external test stimuli or performing measurements.
 I would like to learn what approaches you are taking for firmware testing and I would like to hear your opinion on the proposed approach. If things work out well, we plan to release the framework on GitHub later this spring.
 Best,
Thomas, Software R&D, ams AG
