Cortex M4 exception return sequence
I think I am just getting confused with this even if (or because of) I read the book and manuals again and again.
At exception entry, the processor saves R0-R3, R12, LR, PC and PSR on the stack. Saving PC means that the address of the instruction to be executed next after return from the exception handler is saved on the stack. However, the documentation also says that LR is updated with EXC_RETURN and that when the EXC_RETURN value is loaded to the PC, the exception return sequence begins.
So, the confusion is - it is the stacked PC value which should be loaded to the PC to return to the place where it left to attend the exception handler. If the PC is loaded with EXC_RETURN value, it is not a valid address but that only the lower 5 bits indicate which stack was used and the return mode (thread/handler) etc.
Or is it that the loading of PC with EXC_RETURN is then followed up by loading of the PC with the stacked PC value?
Can someone please help clearing this confusion?
Thanks,
Gopal
