Question about the "hint" instruction - WFI.
The armv7m arch manual (i'm using DDI0403_B, latest?) says it will come out of the suspended / low-power state if:
• A reset.• An asynchronous exception at a priority that, if PRIMASK wasexceptions.Note The processor ignores the value of PRIMASK in determiningwakeup event.
• If debug is enabled, a debug event.• An IMPLEMENTATION DEFINED WFI wakeup event.
and I don't understand all of it.
Point 2 above: Say I start clean from reset with minimal setup, and (pseudo code) in my main is while (true) { __wfi; /* do stuf .. */ } , and I 've left all priorities as default after reset, non-configured un-altered. Are _any_ of Cortex non-NMI/non reset exceptions suppose to wake up my main? i.e, SysTick, Svc, PendSv ? How about external exceptions or interrupts that I've may have enabled through NVIC ? I'm using a CM4 based chip, and , I may have observed it wrong but it seemed to me that my main does not wake up on a peripheral interrupt, and out of the internal exceptions it wakes up on SysTick and SVC, but not on PendSV (it _seems_ ..)
Can an implementation change which exceptions will wake up the processor which is in sleep by wfi?
The part which says "implementation defined" WFI event: will those usually be expected to be specified by the tech ref manual or datasheet for the chip/ SoC? Because, I'm looking at the manual for this chip and I see no mentioning of the WFI & reference to this Implementation Defined part.
Also, Is it configurable at all, which interrupts / events would cause it to wake up from WFI ...? (I would want to ask about WFE as well, but I rather sort one out first).
Is actually using / relying on wfi any good at all for relying to wake up your main thread to check what just has happened ..
Iterating through answers, I probably should have asked something like this originally:
Will using "wfi" always behave as the arch spec says, or can implementations change how it behaves, wrt to exceptions/interrupts? And would implementations usually put in tech refs the implementation defined part ?
Probably first is "yes always shall" but, just in case , should't hurt to ask for just in case..
Another way, if say cortex-m 's wfi is an abstract interface call, do I need to study much the specific realization of it to make sure it at least does what the spec of the base interface says it shall.
