Compiling error "system_MKL25Z4.h" file not found despite linker path provided
I have been trying to compile a GPIO example for the FRDM-KL25Z Arm Cortex-M0+. At the beginning I run into the problem of not finding the path for "MKL25Z4.h". After a quick search online, I found that I had to add the directory path to the project's "Include Paths" (C:/Keil_v5/ARM/PACK/Keil/Kinetis_KLxx_DFP/1.15.0/Device/Include). While this solved the error, another one came out. This time is regarding the "system_MKL25Z4.h" header file. I do not understand why this error surfaced even though I already provided the full path to the directory containing this file.
I would highly appreciate any leads on how to address this situation. Plus, more kudos, if someone could explain to me why adding the full path to the directory does not solve the problem.
Furthermore, I did think of writing the full path to the preprocessor definition inside "MKL25Z4.h". However, I think that there must be a better way to address this error.
  • Your title says "Linker path".
    Header files are used by the compiler - not the Linker - so if you have added it in the Linker options, that's the wrong place!
    Take a look at the diagrams here to see how the tools in the tool chain relate, and which files are associated with which tools.
    You do actually have that file present on your system?
    If that's in a different folder, then you also need to add that to your Includes Path.
    Where did you obtain the example?
    Have you contacted the author/supplier for support with it?
  • Hi Andy,
    Thank you for your time and prompt reply.
    First, you are right. A mistake on my end to say it was a Linker error while it is a Compiler error. What I am getting is a Compiler error.
    The link provided to the diagrams that shows the association between files and tools has been very helpful visualizing and clarifying the tool chain. Many thanks for that as well.
    Yes, I do have that file present in my system, Windows OS. I got the files of interest after downloading the latest software-pack for the Kinetis KLxx series.
    The file is located within the same directory in the Path I provided when I initially started this thread. Further, the same Path has been added into the C/C++ Includes Path section. Attached is picture displaying what I assume is correct "include path" source file addition.
    I've got the code example from the Embedded Systems Fundamentals with Arm Cortex-M based Microcontrollers textbook. This book is produced by ARM Education Media. Plus, I have not contacted the author. I will do that If help from this forum does not lead to a solution in the next few days.
  • I got the files of interest after downloading the latest software-pack
    What is the date of the textbook?
    It's quite possible that the "latest" software pack is not compatible ... ?
  • What is the date of the textbook?
    The book was printed in 2017. The same year of the latest Software Pack.
    Furthermore, it also crossed my mind that the latest software pack might have been incompatible source code example I am using. I did download previous versions. However, since we last communicated, after further online searching and walking through the Pack's file system I found that the "system_MLK25Z4.h" header file at the following path: C:/Keil_v5/ARM/PACK/Keil/Kinetis_KLxx_DFP/1.15.0/Device/Source rather than $SAMEPATH/Device/Include
    A clear picture of what errors I am facing will be posted as a reply to your "What, exactly, is the message?" thread
