I've been reading books on the ARM Cortex-M architecture and as already mentioned in other post, all the books are consistent in saying that the PC points four bytes (Thumb Instruction Set) forward due to Pipeline (prefetch).
Did some testing with debugger, and ended up getting more confused, in theory I fully understand the reasons for the PC is 4 bytes, and perfectly understand the adjustment made by the debugger to display the PC value correctly as the executing statement.
But I was confused when I read that the PC is set temporarily when used to calculate the approximate memory locations to load the registers.
I quote the part that left me very confused, Section 3.1.5 of the book "The Definitive Guide to the ARM Cortex-M3, Second Edition" jyiu:
"In other instructions like literal load (reading of a memory location related to current PC value), the effective value of PC might not be instruction address plus 4 due to alignment in address calculation. But the PC value is still at least 2 bytes ahead of the instruction address During execution. "
Could anyone suggest me a specific reading about this behavior, but more detailed, noting that perfectly understood the operation, but I feel as if something was missing on the subject.
That for many is a trivial question, but I want to go forward with pendencies in the understandings.
Thank you.
For this particular form of LDR instruction:
LDR Rt, [PC, #offset]
The address being used is calculated as:
address = (PC & 0xFFFFFFFC) + (#imm << 2)
Note 1: Lowest 2 bit of PC is clear to make it word aligned before adding the offset
Note 2: #imm is the immediate value inside the instruction code
The align operation (masking bit 1 & bit 0 of PC) ensures that the literal load be word aligned.
As a result of this, the #offset calculated is not necessary PC + #offset + 4.
Hope this helps.
regards,
Joseph
the item 2 about the #imm did not understand well.
The value of offset is encoded using the immediate data value field inside the LDR instruction.
Since we limited the address for 32-bit literal load to be word aligned, and using a word aligned PC for the calculation, the lowest 2 bit of the offset are always 0. So we shift left by 2 bit to allow a larger offset range.
