When I build my code with the following compiler option on STM32L4R9AI (Cortex M4) board with TizenRT (https://github.com/Samsung/TizenRT)
ARCHOPTIMIZATION += -fno-omit-frame-pointer -mapcs -mno-sched-prolog
I do not get a frame pointer (fp) for every call stack of the source code build.
When I take the object dump, I get following call stack >>
08000fb0 <stm32l4_dbgmonitor>: 8000fb0: b580 push {r7, lr}
Whereas, for cortex-R the object dump using the same compiler option (for artik053 board) looks as below >>
I am currently using using gcc version 6.3.0.
Any pointers on this issue would be helpful.
Thanks & Regards,
Vidisha Thapa
You cannot force the compiler to use a frame-pointer. At least I haven't seen one.
But it works in case of cortex R
## for cortex-R the object dump using the same compiler option (for artik053 board) looks as below >>
You compare different C code. This makes no sense.
Hi,I tested it using the same C code >
When I build with R-series I get the frame pointer >
"arm-none-eabi-gcc -c -mcpu=cortex-r7 -fno-omit-frame-pointer test.c"
00000000 <main>: 0: e92d4800 push {fp, lr}
Whereas in cortex M-series I do not get the frame pointer >
"arm-none-eabi-gcc -c -mcpu=cortex-m4 -fno-omit-frame-pointer test.c"
00000000 <main>:
R7 is being used as the frame pointer on the M4.
