I am using an Atmel/Microchip ATSAME70 Cortex M7 processor and was working on getting Ethernet GMAC driver working. The GMAC uses an internal DMA engine to transfer packets to SRAM. I noticed that I was getting some HRESP errors with the DMA transferring data and the peripheral driver was not working. I disabled the data cache and the driver works.
The code polls the SRAM locations to see if a DMA has completed so I tried leaving data cache on and invalidating the cache before reading the SRAM but that did not fix problem. I was wondering if anyone knew of any problems using the data cache and DMAs in peripherals like this?
Note every time I contact Microchip about such problems they inform me that they never test/run code with caching enabled, so they never see any problems.
Trampas
Yes... The ATSAME70 GMAC driver did not align the buffers for the GMAC DMA engine, even though the datasheet had mentioned a requirement that they were aligned.
