I have tryed to make SWD connect to Cortex-M0 DesignStart Eval by STLink2, but it was unsuccessful.
The SW Device showed information as this picture.
I chose AHB_ROM_FPGA_SRAM_MODEL and AHB_RAM_FPGA_SRAM_MODEL be the MYM_TYPE
Assume you are using an FPGA to prototype it:
- make sure you have added suitable tristatre buffer at top level and the polarity of the tristate buffer enable is correct.
- make sure you have setup clock constraint to SWDCLK, and make sure from your synthesis log that the contraints are applied sucessfully.
- check the voltage level requirement of the STLink2 - Some FPGA I/O level might be a bit too low.
Hope this helps.
thanks for your suggestion.
I'll check my setting by your suggestion.
Good luck!
I've checked these settings.
First, I uesed cmsdk_mcu_pin_mux module that has Tristate buffers.
Then, the timing report doesn't show Timing violation.
Finnaly, the I/O standard's is sitted to 3.3V LVTTL model. By the way I've connected CM3Eval to Keil by STLINK2 successfully,that FPGA's I/O standard has setted the same model.
I've viewed some question(community.arm.com/.../fail-to-add-jtag-swd-debug-into-cortex-m0), and there was developer said that CM0Eval did not have Debug function. Is this the reason why I can not find core-sight?
I am looking forward to your reply.
Best Wishes!
There are two releases of Cortex-M0 DesignStart
- August 2010: this version does not have debug
- 2017 version (r2p0-00rel0) has debug
(Update: Serial wire only. See http://infocenter.arm.com/help/topic/com.arm.doc.dui0926b/ch01s03s02.html for limitations)
I will try have a closer look later this week. Meanwhile, if you do have access to another debug probe it worth trying as well. The DAP module used on Cortex-M3 and Cortex-M0 were different and I wonder if this is due to old version of STLink firmware not able to detect the Cortex-M0 DAP correctly.
regards,
Joseph
Thank you so much~
I solved it.
The siganl connection is different from M3Eval.
I'v changed the connection, that was mcu_sys's SWDIOTMS via pin_mux's SWDIOTMS direct connect. I connected CDBGPWRUPREQ to CDBGPWRUPACK.
Finally, I got the SW-DP with ID 0x0BB11477 with DEBUG function!
There are something worng with DEBUG, but I got it at least.
Thanks for your help!
The best wishes!
