Im using an ARM Cortex-M3(LPC1768).I would like to know how many oscillator periods make up 1 instruction cycle for arm.Like for example,12 oscillator periods make up 1 instruction cycle for 8051.
I would like to use the the number of oscillator periods for each instruction in delay calculations for instructions like NOP etc.
Parents Reply
  • albanrampon, you're right about using a timer whenever possible.
    But if you're working with high-speed delays, such as one or two clock cycle delays and your processor runs at more than 20 MHz, then you will need to know the exact timing. It's also necessary to know, in case you need to synchronize an interrupt to a timer. (that is what my sync snippet for Cortex-M0 is intended for; it can be modified to work on the Cortex-M3).
    akshimmu - Normally you count 1 clock cycle per NOP instruction. That could be one oscillator clock cycle, if you've set the PLL to use the main crystal as a 1:1 clock source. But as mentioned in the other answers, you can use the PLL to generate for instance 100 MHz from a 12 MHz clock crystal on the LPC1768 (good choice BTW).
    So if you've chosen to run the microcontroller at 100 MHz, then 1 NOP instruction will take 1 clock cycle. If your external crystal is a 10 MHz crystal, then it means that your NOP instruction is basically using 1/10 "crystal" clock cycle.
    BUT. You also have another factor, the Flash wait-states. If you're running your program from SRAM, then you won't need to worry about it, because the SRAM is zero wait-state. But the Flash memory may want to delay your instructions with something between 2 and 5 clock cycles, depending on your speed. (Normally 3 or 4, though).
    If timing is critical, such as you need to make sure the GPIO pins gets the data at an exact clock cycle number, then copy your time-critical part of your code to SRAM (or even better: Use a linker-script to place selected parts of your code in SRAM), then you will not have to worry about that anymore.
    Now, if you're coming from an 8051, which spends several cycles per instruction, your best choice would be as Alban says: Use a timer. You don't necessarily have to use an interrupt; you may manually poll the Timer Counter too. Using an interrupt, though, is a good idea. Also remember that in many cases, you can use the DMA to do the jobs for you. Eg. You can set up a memory-to-GPIO transfer and synchronize the DMA to a timer, so your data-stream will not suddenly be delayed by interrupt-hickups.
