Function with different types of arguments
Hello!
In the program writen in Keil uVision 4, I decided to redo some of the functions and added the structure:
typedef struct
  GPIO_TypeDef * GPIOx;
  uint16_t PINx;
}GPIO_PINdef;
Previously, the function looked like this:
void GPIO_InitPIN (GPIO_TypeDef * GPIOx, uint16_t GPIO_Pin_x)
Now it looks like this:
void GPIO_InitPIN (GPIO_PINdef GPIOx)
So here is the question, calling a new function now works both in the old and new way, i.e. to call a function in this form
GPIO_InitPIN(GPIOB, GPIO_Pin_8)
and in this form
GPIO_PINdef SPI_CS;
GPIO_InitPIN (SPI_CS);
the compiler does not swear and the program runs correctly.
But everything was fine until I tried to fix "warning" during compilation, namely "function" GPIO_InitPIN "declared implicitly". I copy the function description into the header file and after that everything stops working:
void GPIO_InitPIN (GPIO_PINdef x);
 - adding this description, swears that there are too many arguments when calling this function
How can this function be written in the header?
  • You're assuming arguments are pushed on a stack, in an optimized build, the parameters to the 2 parameter function are probably in registers, and have no address relation to each other.
    One way; you could do a
    union funcTypes { void (*INitStruc)( GPIO_PINdef ); void (*InitParams)( GPIOB, uint64_t ); } ;
    void realFunction( GPIO_PINdef );
    #define paramCall( a, b )   ((union funcTypes*)realFunction).InitParams( a, b )
    #define strucCall( a )   ((union funcTypes*)realFunction).InitStruc( a )
    but really - just standardize on one or the other and don't do any of the above :)
