See my code, which is not counting/reading external pulse from fan. checking with different fan types but did not get pulse.
Please help me to resolve.
#include <lpc17xx.h>#include "uart.h"#include "delay.h"
#define LED 0
volatile uint32_t Freq, Freq2;
int main (void) { UART0_Init(9600); LPC_SC->PCONP |= ( 1 << 15 ); // power up GPIO LPC_GPIO0->FIODIR |= 1 << LED; // puts P0.0 into output mode.
//Initialization of the counter on P1.19 as CAP1.1 LPC_SC->PCONP |= 1 << 2; //Power up TimerCounter1 LPC_TIM1->TCR |= 1 << 0; // Counter mode LPC_TIM1->CTCR |= 3; // Count on falling edges LPC_TIM1->CTCR |= 1 << 2; // CAP1.1 is the input pin for which the input signal needs to be connected. LPC_PINCON->PINSEL3 |= ((1 << 7) | (1 << 6));; // Make P1.19 as CAP1.1 LPC_TIM1->TCR = 0x1; // Enable counter //Initialization of the timer which generates interrupt once in a second LPC_SC->PCONP |= 1 << 1; //Power up Timer0
LPC_TIM0->MR0 = 12499999; // Assuming that clk freq = 100 MHz, this value is calculated to generate an interrupt once in a second. LPC_TIM0->MCR = 3; //interrupt and reset control NVIC_EnableIRQ(TIMER0_IRQn); //enable timer0 interrupt
LPC_TIM0->TCR = 1; //enable Timer0 while(1) { UART0_TxFloatNumber(Freq); UART0_Printf("\n"); DELAY_ms(500); UART0_TxFloatNumber(Freq2); UART0_Printf("\n"); } }
void TIMER0_IRQHandler (void){ LPC_TIM1->TCR = 1;
if((LPC_TIM0->IR & 0x01) == 0x01) // if MR0 interrupt{
LPC_TIM0->IR |= 1 << 0; // Clear MR0 interrupt flag
Freq = LPC_TIM1->TC; // Read the counter valueFreq2 = LPC_TIM0->TC;
LPC_TIM1->TCR |= 1 << 1 ; // Reset the counterLPC_GPIO0->FIOPIN ^= (1<<LED); /* Toggle the LED (P0_0) */
You need a pull up resistor on the tach wire, verify you have one.
