Please assist with Usage Fault /Illegal unaligned load or store Cortex M7 Keil MDK-PRO
Problem
Once in a blue moon (every ~500 hours of run time, non-deterministic) I am getting a Usage Fault/ Illegal unaligned load or store. Please, help me to trace the fault to actual offending instruction and extract additional info.
What have I done so far:
Per ARM AN209 (http://www.keil.com/appnotes/files/apnt209.pdf) I have installed a hard fault handler.
extern C void HardFault_Handler(void)
    __asm volatile
         tst lr, #4                                                \n
         ite eq                                                    \n
         mrseq r0, msp                                             \n
         mrsne r0, psp                                             \n
         ldr r1, [r0, #24]                                         \n
         ldr r2, handler2_address_const                            \n
         bx r2                                                     \n
         handler2_address_const: .word prvGetRegistersFromStack    \n
Values of the registers extracted from the exception stack frame are:
HFSR is 0x40000000 indicating Forced (I do not have a separate handler for UsageFaults)
CFSR is 0x01000000 indicating UsageFault, UNALIGNED access
xSPR is 0100 0003
MMFAR is 0
BFAR is 0
pc (0x0803A758)  points to
a dead loop of osRtxIdleThread.
This could not be the offending instruction, could it? What am I missing?
I have checked the RM0385 Reference manual, I see that the exception stack  has been parsed properly:
My system is:
Cortex M7 (STM32F746NG..)
Keil RTOS
Once the unit is stalled, I have connected to it using SEGGER J-Link/J-Trace for Cortex M (using Ozone), stopped the program, and examined the memory contents.
Unaligned access fault trap (UNALIGN_TRP) is disabled ( per reference it means that only ... can generate this fault)
I read:
https://community.arm.com/developer/tools-software/tools/f/armds-forum/402/debugging-a-usage-fault-for-an-unaligned-memory-access
http://www.keil.com/support/docs/3777.htm (but no external SDRAM is used)
also read:
https://medium.com/@iLevex/the-curious-case-of-unaligned-access-on-arm-5dd0ebe24965
https://stackoverflow.com/questions/18269181/unaligned-access-causes-error-on-arm-cortex-m4
https://stackoverflow.com/questions/20926386/what-is-non-aligned-access-arm-keil
https://stackoverflow.com/questions/5119496/arm-unaligned-memory-access-workaround
