I recently had a race-condition in an application on a Cortex-M4 microcontroller, because I used a wrong order of __SEV() and __WFE() instructions to put my chip to sleep. While debugging this issue, I wondered when exactly the event register does get set. (Link to my related question in the Nordicsemi Developer zone)
Let's assume the following scenario:
Does the event register get set in that case? I assume yes, because according to the reference manual:
In addition, if the SEVONPEND bit in the SCR is set to 1, any new pending interrupt triggers an event and wakes up the processor, even if the interrupt is disabled or has insufficient priority to cause exception entry.
Suppose I clear the event flag by calling _WFE(), and after that the same peripheral fires another interrupt while PERIPHERAL_IRQn is still pending. Does the event register get set again? I assume no, because the manual specifies "any new pending interrupt triggers an event". Because that IRQn was already pending and did not change its state, the event register would not get set again.
Am I right with this assumption?
No, as the pending bit of this interrupt is asserted during this process and does not change
Can you elaborate a bit on your response? I'm not sure what you mean exactly and am not sure which question you are responding to with "No".
Thanks!
