Hi
I am having an issue, related to vector table relocation in a Cortex - m0 based device, as VTOR isnt available there in this core, how can i manage the ISRs in a application which is not at default flash address i.e. 0x8000000, i am able to jump from my boot loader code to the application code, but after interrupt generation code stops. need help thanks in advance
Prasad
You need to "relocate" the vectors yourself. Means, you let the vector point to some piece of code that fetches the final vector from RAM. This RAM contains either the addresses from boot load or from application.
To ease this, you also might want to direct all interrupts (not excpetions!) to one single vector (that's how an RTOS would do it).
