Hello everyone,
I'm trying to learn the interrupt handler and how to program it in c++ but some strange behavior happen.
I set the interrupt on the button press and i debug my application: it is a simple application:
int main(void) { SystemInit(); Buttoninit(); while(1); } // end main;
and my interrupt handlers are:
void EINT0_IRQHandler (void) { LPC_SC->EXTINT &= (1 << 0); */ } void EINT1_IRQHandler (void) { LPC_SC->EXTINT &= (1 << 1); } void EINT2_IRQHandler (void) { LPC_SC->EXTINT &= (1 << 2); }
when i insert my handlers in the main.cpp file, at the top of at the botton as well, the interrupt is couch but redirect to a B instruction to my startup_LPC17xx.s .
In particular to the end B instruction of the following:
Default_Handler PROC EXPORT WDT_IRQHandler [WEAK] EXPORT TIMER0_IRQHandler [WEAK] EXPORT TIMER1_IRQHandler [WEAK] EXPORT TIMER2_IRQHandler [WEAK] EXPORT TIMER3_IRQHandler [WEAK] EXPORT UART0_IRQHandler [WEAK] EXPORT UART1_IRQHandler [WEAK] EXPORT UART2_IRQHandler [WEAK] EXPORT UART3_IRQHandler [WEAK] EXPORT PWM1_IRQHandler [WEAK] EXPORT I2C0_IRQHandler [WEAK] EXPORT I2C1_IRQHandler [WEAK] EXPORT I2C2_IRQHandler [WEAK] EXPORT SPI_IRQHandler [WEAK] EXPORT SSP0_IRQHandler [WEAK] EXPORT SSP1_IRQHandler [WEAK] EXPORT PLL0_IRQHandler [WEAK] EXPORT RTC_IRQHandler [WEAK] EXPORT EINT0_IRQHandler [WEAK] EXPORT EINT1_IRQHandler [WEAK] EXPORT EINT2_IRQHandler [WEAK] EXPORT EINT3_IRQHandler [WEAK] EXPORT ADC_IRQHandler [WEAK] EXPORT BOD_IRQHandler [WEAK] EXPORT USB_IRQHandler [WEAK] EXPORT CAN_IRQHandler [WEAK] EXPORT DMA_IRQHandler [WEAK] EXPORT I2S_IRQHandler [WEAK] EXPORT ENET_IRQHandler [WEAK] EXPORT RIT_IRQHandler [WEAK] EXPORT MCPWM_IRQHandler [WEAK] EXPORT QEI_IRQHandler [WEAK] EXPORT PLL1_IRQHandler [WEAK] EXPORT USBActivity_IRQHandler [WEAK] EXPORT CANActivity_IRQHandler [WEAK] WDT_IRQHandler TIMER0_IRQHandler TIMER1_IRQHandler TIMER2_IRQHandler TIMER3_IRQHandler UART0_IRQHandler UART1_IRQHandler UART2_IRQHandler UART3_IRQHandler PWM1_IRQHandler I2C0_IRQHandler I2C1_IRQHandler I2C2_IRQHandler SPI_IRQHandler SSP0_IRQHandler SSP1_IRQHandler PLL0_IRQHandler RTC_IRQHandler EINT0_IRQHandler EINT1_IRQHandler EINT2_IRQHandler EINT3_IRQHandler ADC_IRQHandler BOD_IRQHandler USB_IRQHandler CAN_IRQHandler DMA_IRQHandler I2S_IRQHandler ENET_IRQHandler RIT_IRQHandler MCPWM_IRQHandler QEI_IRQHandler PLL1_IRQHandler USBActivity_IRQHandler CANActivity_IRQHandler B . ENDP
If in debug mode, i check the address of the EINT0_IRQHandler by positioning the cursor on the text, it is correct and it is the actual adress of the irq handler.
But when i insert my functions handlers to another file, named irq.c, the interrupt point to the correct functions....
Whats the different between putting that functions to a single c file and to a cpp file? what i'm missing in my program?
