volatile variable position in the stack (ABI std)
Hello everyone,
when i'm mixing c code with assembly for cortex m3 processor, I have something that i do not fully understand.
My code behave like this:
    int a=2;
	int b=3;
	volatile int r=8;
	r=assembly_function(a,b);
and compliant to the abi standard, a,b are mapped into registers and the r variable into stack. So my dissasebly code for the allocation of r variable is:
0x00000196 2008      MOVS     r0,#0x08
0x00000198 9000      STR      r0,[sp,#0x00]
Inside my assembly function i want to push something to the stack, for example to pass them into my main function. Lets say i push r3 and r4 so my stack
at the end of my assembly_fuction contains r3,r4 and the r variable before starting the function that now is at r0.
when i come back to my main.c, the return variable is saved into r0 (abi std) so my compiler now update the new value of r variable inside the stack, but in this way:
0x000001A2 9000      STR      r0,[sp,#0x00]
So actually overwriting the r3 value.
Why the compiler is not smart enough to know that into the stack was pushed 2 variable so the correct form for update r variable is str,r0, [sp #0x08]?
So my problem is, how can i understand without actually debugging, that where my compiler puts the volatile variable? In this example the flow is very easy, but
in some others i could have many volatile variable with lots of push/pops of the stack. I'd like to know more about this behavior.
Thank you so much
