During debugging the Cortex-M0+ (ATSAMR21G18) all of a sudden hangs. Stack looks fine. LR contains the correct return address (odd), which based on the BX instruction description (http://www.keil.com/support/man/docs/armasm/armasm_dom1361289866466.htm) I understand as the processor is in thumb instruction mode.
BX LR is the instruction crashing, LR=0x8e5f. Single stepping through the return makes processor hang.
After processor is unresponsive, from debugger console window gdb shows: "Remote failure reply: EE02000002000000383B00200200000000000000343B002001000000343B0020F3B6EDFFDFBF7FF7F3DEFEEFDB37FCD000000000683A00205F8E00008201000000000061".
Is there a way to dig out from this hex code why the processor is not responding or is there another way to get this information?
Thanks for your time,Torben
From map file:
We're not out of bounds in stack:
.stack 0x20001ba8 0x2000 load address 0x0000c958 0x20001ba8 . = ALIGN (0x8) 0x20001ba8 _sstack = . 0x20001ba8 __c_stack_limit__ = _sstack 0x20003ba8 . = (. + STACK_SIZE) *fill* 0x20001ba8 0x2000
and region branched to is valid code:
.text.GetTxFreeSpace 0x00008e38 0x3c .../extcmdTx.c.obj 0x00008e38 GetTxFreeSpace
Arrows (->) indicates the point where I extracted the registers and stack dumps:
UINT16 buffer_free_space = CB_FreeSpace(&TransmitBuffers[TxId]); 443 UINT16 buffer_free_space = CB_FreeSpace(&TransmitBuffers[TxId]);->00008e58: ldr r0, [pc, #20] ; (0x8e70 <GetTxFreeSpace+56>)00008e5a: bl 0x180 <CB_FreeSpace> 444 if (buffer_free_space < (UINT16)sizeof(TRANSMIT_BUFFER_HEADER_TYPE))00008e5e: cmp r0, #13 --- Torben: Never reached!General Registers General Purpose and FPU Register Group r0 0 r1 2 r2 536886072 r3 2 r4 0x0 (Hex) r5 0x20003b34 (Hex) r6 1 r7 536886068 r8 4293768947 r9 4152344543 r10 4026457843 r11 3506190299 r12 0 sp 0x20003a68 lr 0xf11 (Hex) pc 0x8e58 <GetTxFreeSpace+32> xpsr 1627389952 msp 536885864 psp 2675900284 primask 0 basepri 0 faultmask 0 control 00x20003b60 : 0x20003B60 <Hex> Address 0 - 3 4 - 7 8 - B C - F 20003A00 01010101 01010101 01010101 01010101 20003A10 01010101 01010101 01010101 01010101 20003A20 01010101 01010101 01010101 01010101 20003A30 00000000 29360000 01010101 00000000 20003A40 00000000 29360000 00000000 29360000 20003A50 00000000 29360000 00000000 00000000 20003A60 7E3A0020 68140020 00000000 110F0000 20003A70 00000000 29360000 00000000 29360000 20003A80 00000000 00000000 02000000 303B0020 20003A90 AE3A0020 68140020 01000000 10000000 20003AA0 00000000 FE000000 FEFF0000 74140020 20003AB0 01000000 02000000 0E000000 10000000 20003AC0 00000000 CB7E0000 10000000 01000000 20003AD0 00000000 FE000000 FEFF0000 51100000 20003AE0 01000000 00000000 FE000000 FEFF0000 20003AF0 00000000 00000000 01000000 00000000 20003B00 0E930000 05000000 6C060020 00000000 20003B10 FFFFFFFF 1F800000 01000000 00000000 20003B20 FE000000 FEFF0000 00000000 594D0000 20003B30 443B0020 02000000 3C060020 9F800000UINT16 CB_FreeSpace(const COMMS_BUFFER_TYPE *const BufferPtr){ //return BufferPtr->MaxIndex - CB_DataLength(BufferPtr); // == 750 return 750; --- Torben: Hits this breakpoint, but never returns!}CB_FreeSpace:->00000180: ldr r0, [pc, #0] ; (0x184 <CB_FreeSpace+4>)00000182: bx lr --- Torben: lr = 0x8e5f, so remain-in or switch-to thumb instruction set.General Registers General Purpose and FPU Register Group r0 536871232 (0x20000140) r1 2 r2 536886072 r3 2 r4 0x0 (Hex) r5 0x20003b34 (Hex) r6 1 r7 536886068 r8 4293768947 r9 4152344543 r10 4026457843 r11 3506190299 r12 0 sp 0x20003a68 lr 0x8e5f (Hex) pc 0x180 <CB_FreeSpace> xpsr 1627389952 msp 536885864 psp 2675900284 primask 0 basepri 0 faultmask 0 control 00x20003b60 : 0x20003B60 <Hex> Address 0 - 3 4 - 7 8 - B C - F 20003A00 01010101 01010101 01010101 01010101 20003A10 01010101 01010101 01010101 01010101 20003A20 01010101 01010101 01010101 01010101 20003A30 00000000 29360000 01010101 00000000 20003A40 00000000 29360000 00000000 29360000 20003A50 00000000 29360000 00000000 00000000 20003A60 7E3A0020 68140020 00000000 110F0000 20003A70 00000000 29360000 00000000 29360000 20003A80 00000000 00000000 02000000 303B0020 20003A90 AE3A0020 68140020 01000000 10000000 20003AA0 00000000 FE000000 FEFF0000 74140020 20003AB0 01000000 02000000 0E000000 10000000 20003AC0 00000000 CB7E0000 10000000 01000000 20003AD0 00000000 FE000000 FEFF0000 51100000 20003AE0 01000000 00000000 FE000000 FEFF0000 20003AF0 00000000 00000000 01000000 00000000 20003B00 0E930000 05000000 6C060020 00000000 20003B10 FFFFFFFF 1F800000 01000000 00000000 20003B20 FE000000 FEFF0000 00000000 594D0000 20003B30 443B0020 02000000 3C060020 9F800000 Hereafter the processor hangs. From GNU debugger window:Breakpoint 2, GetTxFreeSpace (TxId=TxId@entry=EXTCMD_SPI_SLAVE_TX) at /.../extcmdTx.c:443443 UINT16 buffer_free_space = CB_FreeSpace(&TransmitBuffers[TxId]);Breakpoint 12, CB_FreeSpace (BufferPtr=BufferPtr@entry=0x20000140 <TransmitBuffers>) at /home/developer/projects/cdnz-pan-app-20190424/arm/common/extcmd/comms_buffer.c:7777 }Remote failure reply: EE02000002000000383B00200200000000000000343B002001000000343B0020F3B6EDFFDFBF7FF7F3DEFEEFDB37FCD000000000683A00205F8E00008201000000000061Remote failure reply: EE02000002000000383B00200200000000000000343B002001000000343B0020F3B6EDFFDFBF7FF7F3DEFEEFDB37FCD000000000683A00205F8E00008201000000000061Remote failure reply: EE02000002000000383B00200200000000000000343B002001000000343B0020F3B6EDFFDFBF7FF7F3DEFEEFDB37FCD000000000683A00205F8E00008201000000000061
https://forum.segger.com/index.php/Thread/5225-SOLVED-Remote-failure-reply/ was the answer. This was a J-Link tool problem, not ARM.
