Hi, my app (cortex m3) needs to set up a breakpoint directly from code, in order to jump to an interrupt when an instruction from a certain address is fetched. This WITHOUT using a debugger.
Any hint or tutorial? I think the only possible way is the patch block but it seems quite complicated.
Best regards
Franto
You can use debug monitor exception for that:
- set MON_EN(bit 16) in DEMCR (0xE000EDFC)
- Set FPB comparator register 0-5 for instruction address, with bit 0 (ENABLE) set to 1, REPLACE (bit[31:30]) = b01/b10/b11 depending on address
- Set FPB comparator register 6-7 for literal data address, with bit 0 (ENABLE) set to 1 (bit[31:30] is ignored)
- Enable FPB (FPB control register bit 0 set to 1)
You also need to define your debug monitor handler.
regards,
joseph
Hi, it works!
When it jumps inisde my debug monitor handler though, I need to disable that address breakpoint, otherwise as soon as it exits the handler, the handler is called again ad so on. I suppose that's because the breakpoint is just before the instruction.
I'd like the handler to be called only the next time that my address is met. Any way to do that?
Thanks a lot
You need to do a single step with the breakpoint disabled, and then re-enable the breakpoint and resume.
To single step: set MON_PEND (bit 18) in DEMCR, and then exit debug monitor handler.
Joseph
Hi, I actually tried this same approach on a Cortex M7, but for me setting MON_PEND in the Debug Monitor ISR just caused the ISR to be called again immediately after the ISR ended. It didn't step through an instruction before firing the ISR again. I know there is a bit called MON_STEP, but I cannot find any documentation on it! When I set MON_STEP, nothing happens (no Debug Monitor interrupt, even though MON_EN is set). Any idea where to find documentation for this bit, or any idea why this solution is not stepping?
The Armv7-M architecture reference manual is here: https://developer.arm.com/documentation/ddi0403/latest/
See page C1-696
Do you have a debugger connected at the same time? Debug monitor and halt mode debug cannot be used at the same time.
Hi Joseph, thanks for the manual. I see your point, C_DEBUGEN is set when there's a debug session, and this bit cannot be turned off from SW, only from the debugger. Unfortunately using the EWARM debugger for STM32 processors, there does not seem to be a way to run a debug session without halt mode so that I could still print to the terminal IO, see variables, etc even if I can't halt the processor. Do you think the only way to debug this kind of application will be to use printfs and no debugger at all? What I'm seeking is a way to programmatically disable halt mode, use the debug monitor for some routines, then re-enable halt mode and keep debugging with the debugger within EWARM. Any idea if this is possible?
Unformtunately I don't see any way to get this to work in Armv7-M. What is the aims you are trying to achieve?
Hi Joseph, I am trying to implement an instruction counter. Something like startCountingInstructions(); and int count = stopCountingInstructions(); I already wrote the code for it, but I cannot use it because I am connected to the STM32 with a debugger. I would like to use this instruction counter while also debugging the chip, instead of having to connect a serial terminal and print out 'count' without debugging.
Sorry for the delay.
Instead of using debug monitor, you could use a timer interrupt. For each step, set the timer interval to minimal to start off with, if the stacked PC is unchanged after return to the timer ISR, increase the timer interval by 1 to retry. Eventually, the "single stepping" of the instruction would suceed, and you can move to the next one, with the interval restart from minimun value.
Because the Cortex-M3/M4 has an interrupt entry latency of 12 cycle, and an interrupt exit latency possibly around 10 cycles (I can't remember the exact figure, could be 12 but I am not sure), I would choose the minimum interval as 20 cycle as starting point and increase it 1 cycle at a time.
