Access ETM without using a debug kit
Hi
i'm using Nucleo board F401RE.
i want to access to ETM with code.
i'm using IAR Embedded Workbench
My code:
#define ETM_CR 0xE0041000 // Address of ETM_CR
#define ETM_LAR 0xE0041FB0 // Address of  ETM_LAR
#define UNLOCK 0xC5ACCE55 // Value to unlock the ETM
int main (void)
unsigned int *pointer_1 = (unsigned int *) ETM_LAR;  //  The pointer_1 will point to the address contained in the variable ETM_LAR
*pointer_1 = UNLOCK;  // Cheque UNLOCK to the contents of the memory address ETM_LAR
unsigned int *pointer_2 = (unsigned int *) ETM_CR;  //  The pointer_2 will point to the address contained in the variable ETM_CR
unsigned int var = 0x0;  // I initialize a variable called var
var = *pointer_1;   // I assign the contents of pointer_1 to the variable var
while (1)
printf("Il contenuto in esadecimale è: %p\n", *pointer_1);  // I expect to see on the terminal the value of UNLOCK
