Hi
Related to ARMv7-M architecture:
I am searching through all infocenter documents but still cannot find anything and answer this question: "When an exception is taken into account?" I mean, are exceptions only serviced after the current instruction in instruction flow, or exception can interrupt current interrupt in execution? I have found that exception servicing is asynchronous, but what does that mean? Also, memory access instructions can be abandoned and restated. So, does that mean that it is possible to interrupt it? Does it have something in common with memory attributes (normal, device, strongly-ordered)? Are other than memory access instructions also possible to interrupt/get them restarted? What indicates that for CPU to do? Reference manual seems to be incomplete from this question point of view or I cannot find what I need. Hope you guys can help me. Thank you in advance.
It is a big topic :-|
It depends on the processor's implementation. Armv7-M doesn't specify this, but in the case of Cortex-M3/M4/M7, if the current executing instruction take multiple clock cycles, it can be interrupted subject to some restrictions:
In general, if an interrupt is trigger when there is a read to Device/Strongly Ordered location and the read take multiple cycles, the processor need to wait until this transfer is completed before starting interrupt handling sequence.
FPU memory accesses instructions with multiple data are handled in similar manners as LDM/STM.
Asynchronous exception – architecturally the point the interrupt handling sequence starts is not guarantee to have any constant relationship with instruction stream. For example, when the IRQ arrived when PC is X, by the time stacking happen, the processor could have executed a number of instructions after that point and the stacked PC would be X+Y. This included IRQs, SysTick, NMI, PendSV, asynchronous bus faults (previously known as imprecise bus faults).
Synchronous exceptions – architecturally the interrupt handling sequence start right at the current program counter address (e.g. precise bus faults, Memmanage fault, UsageFault) or next address (e.g. SVC).
I appreciate so much for this answer!! Also, wanted to ask maybe you can provide references to thing mentioned to reference manual or CPU implementation technical manuals?
Hi Karolis,
Sorry for the delay.
For Cortex-M3/M4, the technical reference manual (TRM) has some information:
Cortex-M4:
http://infocenter.arm.com/help/topic/com.arm.doc.100166_0001_00_en/ric1417175930567.html
Cortex-M3:
http://infocenter.arm.com/help/topic/com.arm.doc.100165_0201_00_en/ric1414056338502.html
Unfortunately Cortex-M7 TRM does not include the details in this area.
The Device generic user guide also has some general information about exception handling, but not much about details of the behavior:
http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/BABEHHHB.html
In Armv7-M Architecture Reference Manual
https://developer.arm.com/docs/ddi0403/e/armv7-m-architecture-reference-manual
Section B1.5.10 documented the details of LDM/STM/PUSH/POP/VLDM/VSTM/VPUSH/VPOP handling (ICI bit)
Section A2.4.1 gave some references about the synchronous and asynchronous exceptions.
Some of the information I mentioned in my previous reply I don't really know if they are documented or not.
regards,
Joseph
