The ARM Cortex-M4 Processor Technical Reference Manual states:
To minimize interrupt latency, the processor abandons any divide instruction to take any pending interrupt. On return from the interrupt handler, the processor restarts the divide instruction from the beginning. The processor implements the Interruptible-continuable Instruction field. Load multiple (LDM) operations and store multiple (STM) operations are interruptible. The EPSR holds the information required to continue the load or store multiple from the point where the interrupt occurred.
The Definitive Guide to Cortex-M3 and Cortex-M4 Processors Third Edition states:
Some of the instructions take multiple clock cycles to execute. If an interrupt request arrives when the processor is executing a multiple cycle instruction, such as an integer divide, the instruction could be abandoned and restarted after the interrupt handler completes. This behavior also applies to load double-word (LDRD) and store double-word (STRD) instructions.In addition, the Cortex Ò -M3 and Cortex-M4 processors allow exceptions to be taken in the middle of Multiple Load and Store instructions (LDM/STM) and stack push/pop instructions. If one of these LDM/STM/PUSH/POP instructions is executing when the interrupt request arrives, the current memory accesses will be completed, and the next register number will be saved in the stacked xPSR (Interrupt-Continuable Instruction [ICI] bits). After the exception handler completes, the multiple load/store/push/pop will resume from the point at which the transfer stopped.
So both agree, that LDM/STM/PUSH/POP instructions can be interrupted and are continued where they stopped, when the interrupt is handled.
However, the Technical Reference Manual only mentions the divide instruction as another interruptible instruction. The Definitive Guide is much more vague on this, allowing it for all multi-cycle instructions (Which are all instructions taking more than 1 cycle to execute?), mentioning divide and LDRD/STRD as examples.
So what is actually the case for a Cortex-M4 processor? Are only the divide instructions abortible and will be restarted after an interrupt, as the TRM states? Is this an implementation specific detail and I have to assume that any multi-cycle instruction may be aborted and restarted, depending on the vendor?
If it helps, the background for my question is micro-architecture--aware analysis and having a clear statement on which instructions are executed atomically would help greatly to model interrupt impact.
Thank you in advance for your help.
Kind regards
Hi Phillip,
For divide (UDIV/SDIV) instructions and double word load/store (LDRD/STRD), the instruction execution will be abandoned if an interrupt arrive, and will restart from first cycle after the ISR finished. So they can be interrupted, but not handled in the same way as LDM/STM/PUSH/POP.
In Cortex-M3, some of the multiply accumulate is also multi-cycle (single cycle on Cortex-M4), and they are also in abandoned-restart type.
Cortex-M4 floating point processing instructions (multi-cycles) will continue in the background in parallel with stacking with integer register bank.
regards,
Joseph
Joseph Yiu said:double word load/store (LDRD/STRD), the instruction execution will be abandoned if an interrupt arrive, and will restart from first cycle after the ISR finished
Ah, that's why ldrd is not atomic. So in worst case, the low word is read twice. Which can disturb peripherals.
Hi Joseph,
thank you for your quick clarificaton. It helps a lot.
Also, thank you in general for the "Definitive Guide" series, they are really awesome books!
Kind regards,Phillip
Same for LDM/STM on Armv6-M (there is no ICI/IT bits in the PSR in Armv6-M processors like Cortex-M0/M0+). So if accessing peripherals, and if the register is linked to FIFO, we need to avoid LDM/STM, LDRD/STRD.
You're welcome. :)
