Hi, I am developing a fixed-point MP3 & ACELP decoder on an Arduino Due. I realize that bit-banding makes a RMW sequence atomic but I notice fields in the Due hardware are multi-bit fields. Is there an atomic way to alter multiple bits? I realize that the atomic RMW can probably allow the applications/IRQ/NMI to resolve which gets access to the bus but if that is the only real use, wouldn't it have been simpler to use atomic test-and-set as the SuperH does?Examples like the PERIPH_PTSR (bits 0 & 8 used) are classic. Do you write to separate bytes, perform 2 bit-band operations or write to 16 or 32 bits at once?I do appreciate that this is very low level. I also note that TCM (tightly coupled memory) is mentioned just once and I'm not quite sure if this refers to part of the cache or a PSX-like scratch-pad. The PSX was another machine that needed hand-written assembly language to get the full performance out of it.Many thanks,Sean
