Hi ,
If I generate the elf file from the Default bootcode and pagetables , I get a very small size but
after mapping the Stack pointer to SRAM , I am getting a huge HEX file.
Here is the loader file code
MEMORY{ rom (r) : ORIGIN = 0x00000000, LENGTH = 0x3FFFF /* pageTable (rw) : ORIGIN = 0x0B000000, LENGTH = 0x3FFF */ heap (rw) : ORIGIN = 0x02001000, LENGTH = 0x1FFF /* stack(rw) : ORIGIN = 0x0B120000, LENGTH = 0xFFFF */ /* data_mem (rw) : ORIGIN = 0x02020000, LENGTH = 0xFFFF bss_mem (rw) : ORIGIN = 0x02020000, LENGTH = 0xFFFF */ ram (rw) : ORIGIN = 0x02004000, LENGTH = 0x3FFF}
SECTIONS{
/* Code starts with bootcode, then the vector table, then the * remainder of the code */ .text : { *bootcode.o(boot) *vectors.o(vectors) /* *(.text) /* remainder of code */ } > rom
.heap : { *stackheap.o(stackheap) } > heap . = ALIGN(4);
/* Data */ /* __data_start = .; */ .data : AT (_sdata ) { . = ALIGN(4); _sdata = .; *(.data) *(.data*) } > ram
I dont understand what is the Issue here.
The size of the Hex generated is 79MB.
Aashish
The HEX file contains all the data. If you have a gap, then it will end up in the HEX file. If you look at it you will likely find a lot of zeroes.
Thanks for the info.
I see lot many 00000000 in the hex
Is there a way I can skip adding all the 00000000 from the hex
It seems that the usage of the AT keyword, as applied to the data section, is erroneous - it sets LMA=VMA (_sdata tracks VMA, but what was intended by AT(_sdata) was to set LMA as /distinct/ from VMA of the corresponding section).
Assuming that we agree to copy the sections to their link-addresses (VMA) at runtime, a sample script such as below can be utilized for a simple project.
MEMORY { rom (rx) : ORIGIN = 0, LENGTH = 32k ram (rw) : ORIGIN = 0x02000000, LENGTH = 16k } SECTIONS { .text : { *(.text) } >rom .code : { _code_load = LOADADDR(.code); _code_start = .; *(.code) _code_end = .; } >ram AT>rom }
The .code section is adjacent to the .text section, when viewed through their load addresses (LMAs). objcopy should locate them as such in the '-O binary' copy.
At runtime, the .text section must run a piece of code to copy the .code section (src address == load address == _code_load) to the address where it has been linked (0x02000000).
