interrupt distribution on A53 processor
     Linux Kernel 4.9
     Processor a53
      SMP 64 Bit linux image
Issue seen:- Ethernet interrupts are seen arriving only on core0 ONLY, though core0 is completely occupied by other interrupts.
moving ethernet interrupts to other core via smp_affinity, helps drastic reduction in latency [increase in output/Transmi packets per second]
questions
1. if i understand correctly there is GIC based distributor inside ARM processor
2. my dts does init the GIC
3. Is there any config or setting required in Linux build [any change in dts or CONFIG in  linux ]to ENABLE interrupt distributor?
4. my understanding was SMP Linux itself defaults to distribution in interrupts across cores,
please point to any resource/notes in this regard
RC Reddy
