AXI 4 protocol - can read transaction and write transaction occur at the same time?
In addition can 2 or more wrirte transacation occur at the same time?
  • AXI 4 protocol - can read transaction and write transaction occur at the same time?
    Sure, of course.
    No, write transaction uses write channel, they must be sent in order.
  • Under the assumption that by "occur at the same time" you mean "be outstanding at the same time", then the answers to your questions are:
    [S] Yes
    >>In addition can 2 or more write transactions occur at the same time?
    [S] Yes
    NOTE:
    - A read transaction is defined to be outstanding from the cycle in which ARVALID/ARREADY handshake happens to the cycle in which the last (as indicated by RLAST) associated RVALID/READY handshake happens
    - A write transaction is defined to be outstanding from the cycle in which the earliest of AWVALID/AWREADY and WVALID/WREADY handshakes happens to the cycle in which the associated BVALID/BREADY handshake happens
