SMC flow on ARMv8
Hi everyone,
Wherever I go on internet, the thing I read is that when SMC instruction is executed an exception is generated, it takes you to the highest exception level (EL3) where secure monitor is running.
In ARM v8 vector table, given on ARMv8-A architecture reference manual page 1800, there are four types of exceptions:
  1. Synchronous
  2. IRQ or vIRQ
  3. FIQ or vFIQ
  4. SError or vSError
As there is no exception with name SMC, I want to ask under which exception type does SMC fall? If I have a baremetal program running on Cortex-A72, what do I need to do if want to write a SMC handler?
Any answers will be highly appreciated,
  • A SMC exception is a type of synchronous exception. Synchronous exception share a common entry in the vector table.  Within the handler you have to read the Exception Syndrome Register (ESR_ELx) to get the type of synchronous exception (EC field), and any additional information the processor can give you (ISS field).
    For example, for a SMC exception ESR_ELx.EC would read b010011 (if from AArch32) or b010111 (if from AArch64).
