I wanted to check the value of following interrupt related registers i.e.
ICC_IAR1_EL1
ICC_EOIR1_EL1
I'm able to find the ICC_IAR1_EL1 inside the CORTEXA53 hierarchy.
But NOT able to locate ICC_EOIR1_EL1.
Can somebody help me to point the path of this system register?
Not sure what you mean, but did you check the GIC manuals? For example ARM IHI 0069A.
Hi Bastian,
Thanks for taking time to write for it.
I wanted to check the value inside the above mentioned registers after programming a particular Interrupt ID i.e. INTID. Now in the waveform dump I'v to go to the hierarchy inside the CORTEXA53 to load the signals in the waveform. I'm able to find the signals corresponding to ICC_IAR1_EL1 but not for ICC_EOIR1_EL1. In fact, CORTEX/GICv3 documents does not talk about that.
Thanks.
Maybe you should clarify what you are talking about? "waveform dump", signals? Are you talking about logic level or software or debugger?
I'm talking about RTL level logic simulation dump!
There we define registers as well as signals as part of RTL description of the design under test (DUT).
