Systick precision
Hi all,
To prove that my code was configuring the systick counter correctly, I did a small test. To measure the interval length between each SysTick interrupt handler I used SWV in combination with my IDE (Atollic TRUEStudio), which provides a clock tick count for whenever the microcontroller enters or leaves the handler.
Now the silly thing, I am missing clock cycles. Depending on both the system clock frequency and the configured interval between the Systick interrupts I am missing clock cycles, hence the interval is shorter then expected. For a high clock frequency and short Systick interval, I am not missing any clock cycles, but for a low frequency with a longer systick interval I am missing up to 7 clock cycles.
As this is hardware and fairly simple to use I assume I either oversaw something or my measurement technique is not accurate. Does anyone has an idea?
