I am running following code in Cortex-M3.
asm(" MOV R1,#0xFF0"); asm(" MOVT R1,#0xFFFF"); asm(" MOV R4,#0xAA0"); asm(" MOVT R4,#0xAAAA"); //start address asm(" MOV R3,#0x0000"); asm(" MOVT R3,#0x2018"); //end address : 1kB address asm(" ADD R2,R3,#0x40"); //writes asm("BACK: STM R3!,{R1,R4}"); asm(" CMP R2,R3"); asm(" BHI BACK");
As per AHB, when multi-burst operation such as NONSEQ-SEQ happens, the HBURST should NOT be 0 (SINGLE). But with this, I see HBURST =0.
Is that allowed?
HBURST should be 1. Cortex-M3 RTL does output 1 in HBURST in this case. Is somewhere else in the system not hooking up HBURST correctly?
Regards,
Joseph
Thanks Joseph, for your quick reply. You are right, Cortex gives HBURST =1 and the RTL in a distance instance hardcodes that to 0.
