Instruction Modification: DCCMVAU and write buffer
The ARMv8-A-TRM provides the code snipped shown below, under section K9.5.2 within subsection "Ensuring the visibility of updates to instructions for a uniprocessor":
Assume that the memory, to which the instruction is being written, is Normal, Write-Back, Write-Allocate.
Suppose that the STR instruction encountered a cache-miss. The write buffer consumed the write, to allow the CPU to proceed.
The CPU then went on to execute DCCMVAU, with the write still within the buffer.
How does DCCMVAU affect the pending writes in the write buffer?
Why is an instruction to drain the write buffer not needed between STR and DCCMVAU? (Possibly because DCCMVAU drains the buffer too?)
AArch32
P1
 STR R11, [R1] ; R11 contains a new instruction to be stored in program memory
 DCCMVAU R1 ; clean to PoU makes the new instruction visible to the instruction cache
 DSB
 ICIMVAU R1 ; ensures instruction cache/branch predictor discards stale data
 BPIMVA R1
 DSB ; ensures completion of the invalidation
 ISB ; ensures instruction fetch path sees new instruction cache state
 BX R1
Thank you,
Amol
  • The presence of a write-buffer, whether caches are write-back or write-through, whether the I-cache is coherent with the D-cache, etc. etc. are implementation choices. Different processors will have different arrangements of these components, as they make different trade-offs between power, area, performance, design complexity, etc.
    The role of the architecture is to guarantee a common software programmers' model between these different choices.
    So, if you have a particular CPU implementation where for the I-cache to have visibility of an update to an instruction made by the STR instruction, a "write-buffer" has to be drained (i.e. the Point-of-Unification is below this "write-buffer"), then the DCCMVAU (clean to PoU) has to "drain" this "write-buffer". If the PoU is above the write-buffer, then it doesn't.
    Although there isn't a definitive answer, hopefully this explanation is useful to explain why: from the software programmer's point-of-view, you don't care about whether the write-buffer is drained; you care about whether the update to the instruction is visible to the I-cache, and you want code that does that without worrying about the implementation.
