I am writing an embedded operating system targeting arm cortexm 4... I am working on context switching .. I can switch the kernel into user program and go back. but SVC call seems not work well.
syscall: svc SYSCALL_SVC_NUMBER bx lr
when calling svc it trigger interrupt, I can see the control flow go back to kernel. The hard fault arise when it gets back to user program.
around here --> bx lr
I've checked that all the registers are correctly loaded, except that xPSR lacks of thumb bit. That's why the hard fault comes.
But I have no idea why xPSR is clear to zero...
(the input to activate function is the pointer to the top of user stack)
.global activate activate: /* save kernel state in ip register */ mrs ip, psr push {r4, r5, r6, r7, r8, r9, r10, r11, ip, lr} /* switch to process stack */ msr psp, r0 mov ip, #2 msr control, ip ldr ip, [sp, #0x38] msr psr_nzcvq, ip /* load user state */ pop {r0, r1, r2, r3, r4, r5, r6, r7, r8, r9, r10, r11, lr} add sp, #0x8 ldr ip, [sp, #-0x8] /* this line can branch correctly */ bx ip
I've read that fromhttp://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0553a/CHDBIBGJ.html the branch operation may clear T bit, but why?? when will it happen?
