Hello
If two OS running on 64-bit Hypervisor. One OS is 64-bit and other is 32-bit OS.
How the Hypervisor run both OS? What is programming sequence( respect to ARM registers) when Hypervisor schedule/run one after other OS?
I only knows that RMR_ELx use for 32-bit to 64-bit transition but How it will use in Hypervisor based environment?
I have same question with respect to secure world.
If two OS running in secure world say one is TEE(64-bit) and RTOS(32-bit). How the monitor(running in EL3) handle this?
Bharat
