ARM v7 Instruction Set Architecture Opcode Code
I am working with some ARM hardware and I wrote a program in ARM Assembly. The ARM hardware that I am using requires the the program to be in HEX values and I found a website online that allowed me to convert the ARM Assembly language to HEX, the converter I used is 'x32 - ARM32/AArch32/ARMv7'. I would like to verify that the online converter works correctly so I have been looking online for an ARM Instruction Set Architecture document or manual for ARMv7.
I did find the manual for ARMv7 but I couldn't find the Opcode HEX values for the corresponding ARM assembly commands. I am been searching online but no luck.
Any advice? Or information about where I can find a chart, list, or document about ARM Assembly HEX opcodes?
Thanks,
David
