Where can I find the device-specific JTAG instructions for Cortex-M3?
I'm trying to communicate with a Cortex-M3 based microcontroller (LPC1769) through JTAG. I already have the hardware required, and have managed to get an example program to work, but to progress further, I need to know the device-specific JTAG instructions that are available in this case. I have read the corresponding section of the Cortex-M3 technical reference manual [1], and all that told me, was that the device uses a standard CoreSight debug port. In particular, I'd like to read the device ID with the IDCODE instruction. Some sites suggest, that the IDCODE might be b0001 or b1110 for this device, but neither of them seem to work. b0001 seems more likely to me, as that's the value I read from the IR after the TAP has been reset.
I also considered the possibility, that the instruction I'm using is correct, and I'm just not reading the device ID register properly. I'm using an FTDI cable with the FT232H chip, and the application I'm using is based on FTDI's AN129 example code [2], using MPSSE commands. I use the 0x2A command to clock data in from the TAP, the 0x1B command to clock data out to the TAP, and the 0x3B command to do both simultaneously. If anyone could provide some insight, as to what I'm doing wrong (or whether I'm using the right IDCODE instruction at all), that would be much appreciated.
  [1]: infocenter.arm.com/.../DDI0337E_cortex_m3_r1p1_trm.pdf
  [2]: www.ftdichip.com/.../AN_129_FTDI_Hi_Speed_USB_To_JTAG_Example.pdf
