I have to port some assembler code of a Cortex M4 to a Cortex M0+.
At the Cortex M4 this was used:
EOR R3,R3,R6,LSL #16
For the M0+ the arm architetcure reference v6m in chapter A6.7.23 says for the EOR:
Exclusive OR (register) performs a bitwise Exclusive OR of a register value and an optionally-shifted register value, and writes the result to the destination register
But at the description of the encoding this was written:
d = UInt(Rdn); n = UInt(Rdn); m = UInt(Rm); setflags = !InITBlock();(shift_t, shift_n) = (SRType_LSL, 0);
Which was interpreted from me as there was no optionally-shift. Because shift_n was declared as 0.
But in the pseudo-code-part "Operation" this was written:
if ConditionPassed() then EncodingSpecificOperations(); (shifted, carry) = Shift_C(R[m], shift_t, shift_n, APSR.C); result = R[n] EOR shifted; R[d] = result; if setflags then APSR.N = result<31>; APSR.Z = IsZeroBit(result); APSR.C = carry; // APSR.V unchanged
That seems as that a shift was supported.
I didn`t found a syntax which was accepted from my compiler. So my question was, ist the "optionally-shift" only a mistake in writing or has the EOR the possibility to shift?
Best regards
Volker
