I am using imx6 (cortex- A9) board, and my mmu environment is as follows mmu - enabled L1 data cache - enabled L1 instruction cache - enabled D-side prefetch - enabled L2 cache - disabled Branch prediction - disabled
With this environment, my code runs for a longer time (more than 12 hours) with out any issues.But, if I enable branch prediction, the code aborts in few seconds, at random addresses.I am not able to understand what goes wrong. Are there any special option which I have to consider while building my code.I am using GCC as the compiler.
Note : In my code, I am using a static library, which was given by our vendor.
Any help would be great.
Thanks,
Gopu
In the PMU module, vdd values were not properly configured for ARM core clock. After configuring this properly, we were able to solve this issue. Sorry for the late reply. Hope this helps someone in future.
