multiply all array element in cortex-m4
void scale1(uint32_t dst[], uint32_t src[], uint32_t size, uint32_t value){
   uin32_t i;
   for(i=0;i<size;i++){
      dst[i] = src[i]*value;
void scale2(float32_t dst[], uint32_t src[], uint32_t size, float32_t value){
   uin32_t i;
hello all, I'm learn cortex-m4 which has dsp instruction
may I ask like code above, when I need to multiply all array element,
is there a much faster way to handle this situation,
is the way can be suitable for multiplier is float type?
thanks all, for giving me any idea =)
  • Hi there !
    Cortex M4 can handle parallel multiply only wih accumulation (MAC) ... but it can only do this on 16-bit data. Therefore I doubt that you could do much better than this.
    Maybe you could unroll a bit and fetch 64-bits at one time, but still no DSP feature to be used.
    Sorry for this quite pessimistic reply ...
