while I was working with an imx6 board, I got the following behavior: normal world code triggered an external abort (was in the PCIe driver) just before a switch from NS -> S, so the abort actually happened in the Secure world.
My goal is to detect such scenario et correctly ignore the EA in the secure world. I started to test in the monitor if the ISR[A] bit is set or not, to detect a pending Abort from NS, and in this case, I take the abort with a special abort handler (which is a nop, just to clear the ISR).
Sadly, I don't have the board anymore to test this behavior, and my current board doesn't trigger EA.
Is there a way to trigger an _asynchronous_ external abort via software, in a more or less predictable way ?
Best,
Vincent
