Hi community,
I have tried to compile the source code for openVGI have given proper cross compiler which is required by the platform still I am getting the error of unknown mnemonics for the instruction UQSUB8
Environment:
- Linux platform
- CROSS COMPILE tool chain = aarch64-linux-gcc
- ARMv8-a architecture
Code snippet:
for (i = 0; i < 256; ++i) { c = lut[i]; /* Extract alpha and clamp color components */ inva = 0x01010101 * ((~c) & 0xFF); c = _mali_osu_sataddu8(c, inva); cpu_ptr[i] = _mali_osu_satsubu8(c, inva); }
MALI_STATIC_INLINE u32 _mali_osu_satsubu8(u32 x, u32 y) { u32 retval; __asm__("UQSUB8 %0, %1, %2" : "=r"(retval) /* output */ : "r"(x), "r"(y) /* input */ ); return retval; }
Can you please suggest me how can I solve this issue?
Thanks,
DP
In 64 bits mode, there is no UQSUB8 in ARMv8. However you might be able to use the SIMD alternative instead :
- ARM Compiler armasm User Guide Version 6.5 | UQSUB (vector) – ARM Developer
UQSUB Vd.T, Vn.T, Vm.T Where:
Vd
T
Vn
Vm
Where:
Is the name of the SIMD and FP destination register.
Is an arrangement specifier, and can be one of 8B, 16B, 4H, 8H, 2S, 4S or 2D.
8B
16B
4H
8H
2S
4S
2D
Is the name of the first SIMD and FP source register.
Is the name of the second SIMD and FP source register.
Hi myy,
I have changed the code as suggested by you to
MALI_STATIC_INLINE u32 _mali_osu_satsubu8(u32 x, u32 y) { u32 retval; __asm__("UQSUB %V0.S[0], %V1.S[0], %V2.S[0]" : "=r"(retval) /* output */ : "r"(x), "r"(y) /* input */ ); return retval; }
u32 retval;
return retval;
and I am getting below error:
error: invalid 'asm': incompatible floating point / vector register operand for '%V'
As per my earlier answer, if you have access to the OpenVG source code you must be a licensee, so please raise any questions about building the user-space parts of the Mali driver source for your platform via support@arm.com. We cannot provide support for the proprietary parts of our products on a public forum.
FWIW I doubt the OpenVG driver will work on ARMv8; it was only ever released officially with ARMv7-A support (at the time it was released ARMv8 didn't even exist).
Thanks, Pete
